LCD on 18f6585 not working....
dieter
PostPosted: Sat Oct 08, 2005 5:27 pm     Reply with quote
Hi, i connected a 16x2 lcd which i tested with standard lcd.c driver on a pic. So far, so well. Now i connected it on other pins as the following:
RS:A4
RW.B2
EN:D2
Data0-3:B4-B7
the lcd is connected via a flat cable(20cm) and every line is pulled-up by a resitor of 50k. Contrast on pin 3 works correctly and is visible. But the display wont work...Even with marks driver...every line is connected on its right place as i tihnk. is there another fuse to set or does enable line not need any pullup? i already disabled all_analogs. but it still doesnt work on my 18f6585... what could be wrong? thanks...
PostPosted: Sat Oct 08, 2005 9:48 pm     Reply with quote
Data0-3
When an LCD is used in 4-bit mode, it uses the upper 4 bits to talk
to the micro-controller. i.e., DB4-DB7 on the LCD.
You're using the lower 4 bits on the LCD. So you need to change that.
dietmar
PostPosted: Sun Oct 09, 2005 4:19 am     Reply with quote
Well this is not my problem. propably is was a fault to say i use data0-3, but i am already using D4-D7...This is not the problem i think...
PostPosted: Sun Oct 09, 2005 10:31 am     Reply with quote
Try the LCD driver that I recently posted in the Code Library.
It's very easy to modify.
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
To modify it for your board, just comment out the Pin definitions
at the top of the file and use these instead:
#define LCD_DB4   PIN_B4
#define LCD_DB5   PIN_B5
#define LCD_DB6   PIN_B6
#define LCD_DB7   PIN_B7
#define LCD_E     PIN_D2
#define LCD_RS    PIN_A4
#define LCD_RW    PIN_B2
To test it, write a simple program that outputs "Hello World" to
the LCD. Something like this:
#include <16F877.H>
#use delay(clock = 4000000)
#include <flex_lcd.c>
setup_adc_ports(NO_ANALOGS);
lcd_init();
lcd_putc("Hello World");
Also, in a previous thread, you were planning to use a 74HCT14
schmitt trigger inverter chip. I assume that you removed that
chip for your tests. The lcd driver shown above will not work with
the inverter. So make sure you remove it.
