do while timeout?
Goto page 1, 2  Next
edhaslam
do while timeout?
PostPosted: Fri Oct 07, 2005 5:47 am     Reply with quote
Hi All,
I'm trying to implement a timeout for a do while loop that could potentially loop for ever if a character isn't received.
I've tried the following but it doesn't seem to work:
            long timeout;
            timeout=0;
            do
               ch=getch();
               delay_us(10);
               timeout++;
            while (ch != 'B'||(timeout>100000));
This should time out after a second, but just loops forever. Is what i'm doing correct or is there a better way to do this?
Ed
Mark
PostPosted: Fri Oct 07, 2005 5:58 am     Reply with quote
A long is 16bits
100000 would require a 32bit number
declare it as int32 instead
PostPosted: Fri Oct 07, 2005 6:19 am     Reply with quote
There is also another caveat. As written, if no character arrives, it'll sit waiting in the 'getch', and never increment the 'timeout'. Use:
long timeout;
     timeout=0;
     ch=0;
     do {
          if (kbhit()) ch=getch();
          //Remember that the loop itself will include several
          //instructions, so depending on processor speed, the
          //'loop time', will probably be more like 20uSec
          delay_us(10);
     } while (ch != 'B' && (timeout++<50000));
To give 'exit after time', even if no charactrs arrive.
Humberto
PostPosted: Fri Oct 07, 2005 6:22 am     Reply with quote
            do
               ch=getch();
               delay_us(10);
               timeout++;
              }while (ch != 'B'||(timeout>100000));
getch() seat and wait until a char is received,
so timeout would never increment.
To get a running loop, timeout should be incremented inside a timer interrupt
handler (in background) or modifying your code adding kbhit()
            long timeout;
            timeout=10000;    //   10K !!!
            do
               if(kbhit())
                 {ch=getch();}
                 {delay_us(100);   //  100us !!!
                  timeout--; }
              }while (ch != 'B' && (timeout));
Humberto
Edited by Humberto
Hi Ttelmah, we are responding in a shared way at same time!!!
edhaslam
Mark wrote:
A long is 16bits
Ah, yes. Silly mistake!
I've just re compiled but it still doesn't seem to jump out of the do-while loop. It must be getting stuck somewhere else in my code. Here's what I have so far. It is a comms function that send 32 blocks of 128 byte data over the serial port. Before the first block and subsequent blocks are sent, the hardware must receive a 'B' character from the PC in order to proceed:
void TxData(void)
#define DATA_BLOCK_SIZE      125
#define DATA_BLOCK_NUM       31
char ch;
int  data, B;
long block_inc=0, x=0, mem_pointer=0, i;
int32 timeout;
      putc(0x52);                             // Send 'R' char for 'Ready'
      disable_interrupts (GLOBAL);            // Turn off during async Tx
      lcd_gotoxy(2,1);
      printf(lcd_putc,"\f\ Downloading Data!");   // Send start message
      lcd_gotoxy(2,2);
      printf(lcd_putc,"Tx at 9600-8-N-1");         // Display data Tx rate
      delay_ms(1500);
      for (i=0; i<DATA_BLOCK_NUM; i++)        // 32 blocks of data to Tx
           timeout=0;
            do
               ch=getch();
               delay_us(10);
               timeout++;
               for (x=0; x<DATA_BLOCK_SIZE; x++)  // 128 bytes of data tx
                     data = read_ext_eeprom (DATA_BLOCK_SIZE +
                     mem_pointer * 256));                                       mem_pointer++;
                     if ( data == 0x101 )          // Quick check on data integrity
                        printf(lcd_putc, "%u Out of Range\r\n", data); // Out-of-range
                        delay_ms(3000);
                         printf ("%03u", data);        // Send data sample
                         delay_ms (0.4);
      lcd_gotoxy(3,1);                          // Print message at pos 1, line 1
      printf(lcd_putc,"\f\ Download Complete!"); // Send 'done' message to display
      delay_ms(2000);
      enable_interrupts (GLOBAL);             //Turn interrupt on again
Any comments welcome!
Ed
edhaslam
PostPosted: Fri Oct 07, 2005 6:26 am     Reply with quote
You beat me to it! Many thanks guys, I can see what I'm doing now. I'll let you know how I get on.
Cheers,
Ed
PostPosted: Fri Oct 07, 2005 7:03 am     Reply with quote
Hi Humberto,
It is amazing how often that happens. You post an answer, and sombody else has already posted an almost identical comment. There was a thread here a while ago, with about five answers all posted 'overlapping' like this!. Very Happy
edhaslam
PostPosted: Fri Oct 07, 2005 7:24 am     Reply with quote
Ttelmah wrote:
Hi Humberto,
You both must have posted about a second before I did!
Ok, I've got the loop working now Smile
BUT, I still have a problem. The function txdata.c, shown below, doesn't return to the main program if I re enable the global interrupts:
void TxData(void)
#define DATA_BLOCK_SIZE      125             // Size of block to transmit
#define DATA_BLOCK_NUM       31              // Number of blocks to tx
char ch;
int  data, B;
int32 timeout;
      lcd_gotoxy(2,1);
      lcd_gotoxy(2,2);
      delay_ms(1500);
            timeout=0;
            ch=0;
            do
               if (kbhit())                // Time out to prevent infinite loop
               ch=getch();             // Several instructions so
                                             // 'loop time' will probably be more like 20uSec
               delay_us(10);
             while (ch != 'B' && (timeout++<30000));
               for (x=0; x<DATA_BLOCK_SIZE; x++)  // 128 bytes of data to Tx
                     data = read_ext_eeprom (DATA_BLOCK_SIZE + (mem_pointer * 256)); // Get sample data: 8-bit
                     mem_pointer++;                 // Keeps track of next memory 'block'
                        delay_ms(3000);
                         delay_ms (0.4);
enable_interrupts (GLOBAL);             //Turn global interrupt on again
So if don't dissable/enable the interrup in this function, everything works fine. If I do, the program halts at the 'printf(lcd_putc,"\f\ Download Complete!");' .
Is there any reason why this might happen?
Cheeers,
Mark
PostPosted: Fri Oct 07, 2005 7:39 am     Reply with quote
A couple of comments
delay_ms (0.4);
isn't really valid. You need to use whole numbers.
What happens if you don't get a 'B', you still keep on sending and waiting for subsequent B's. You ought to have a failure mode.
edhaslam
PostPosted: Fri Oct 07, 2005 8:12 am     Reply with quote
delay_ms (0.4);
Good point
Yes, the amount of Bs sent by the PC to the hardware governs the amount of blocks of data that the hardware sends to the PC.
Mark
PostPosted: Fri Oct 07, 2005 8:29 am     Reply with quote
edhaslam wrote:
delay_ms (0.4);
Good point
My point is that is you timeout once, then the PC is probably not sending the B's anymore but you still keep trying. I think you should bail out or your program will appear to hang for a very long time.
arunb
RE:
PostPosted: Fri Oct 07, 2005 8:32 am     Reply with quote
Just use the RS 232 receive interrupt. That way all you have to do is enable the interrupt and then sit in an inifinite Do...While loop.
thanks
arunb
edhaslam
PostPosted: Fri Oct 07, 2005 8:40 am     Reply with quote
Yes, I see what you mean. But the program does exit in practice, but as soon as I add in the enable/disable global interupts it hangs. Is it because of how the whole loop has been designed? Can you suggest a better way of doing this part of the code?
The structure is: the PC sends a 'G' character to the hardware which trips the RDA interrupt. This calls txdata() which sends an 'R' character to tell the PC it is ready to send the data. The PC then sends a B character for every block it needs to receive.
Ed
Mark
PostPosted: Fri Oct 07, 2005 8:48 am     Reply with quote
Test for the B after the while loop. You can set a flag and break from the for loop or you could make the txdata return a value and just do a return(false) if you don't get a B. If you set a flag, and the bottom, you test for the flag and display a failed message. Of course you could do this inside the check for B inside the for loop.
edhaslam
PostPosted: Fri Oct 07, 2005 8:58 am     Reply with quote
The strange thing is that it does seem to work if I don't dissable and enable the global interrupts?!
Goto page 1, 2  Next
Page 1 of 2
