display integer variable on LCD
Sensor
PostPosted: Thu Oct 06, 2005 8:35 am     Reply with quote
I'm having trouble displaying an integer variable on an LCD. I have my own LCD driver written and it works great when I send it a single char or a string. Now, I want to take an integer variable and display it but can't. It display junk. For example, if my integer variable I want to display is NUM, and NUM = 123, I want my LCD to display 123, but intead it displays junk.
I am using PCW compiler, IDE version 3.30, PCB version 3.155, PCM version 3.155, PCH version 3.155.
Here is a simple program:
void main() {
   setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
   port_b_pullups(TRUE);
   setup_timer_1(T1_EXTERNAL|T1_DIV_BY_8);
   setup_vref(FALSE);
   set_timer1(0);
   lcd_putch("El Angle:   00.0");   //works fine
   el_angle = 2000;   //normally I will have this would be a counter
                  //but for now I'm just using a constant
      temp = el_angle * 750;      //these convert my counter to the
      converted_el = temp / 8000;   //corresponding elevation angle
      LCD_XY(1,12);   //places the cursor on line 1, position 12 of the LCD
      lcd_putch(converted_el);
      delay_ms(4000);
      el_angle=el_angle+10;
The line "lcd_putch(converted_el);" does not work correctly.
jecottrell
PostPosted: Thu Oct 06, 2005 8:39 am     Reply with quote
Need to see: lcd_putch()
Without that, I don't think anyone will be able to help.
rnielsen
PostPosted: Thu Oct 06, 2005 8:43 am     Reply with quote
Try puting your variable into a Char variable first.
char text[17];
sprintf(text, "%d", converted_el);
lcd_putch(text);
Give that a shot.
Ronald
Mark
PostPosted: Thu Oct 06, 2005 8:46 am     Reply with quote
NUM is a number! Not a string. You must first convert 123 to '1' '2' '3' and print each of these characters.
printf(lch_putch,"%lu",converted_el);
Sensor
PostPosted: Thu Oct 06, 2005 9:24 am     Reply with quote
Thanks,
The printf worked. I had tried the sprintf yesterday but had no luck.
Ok so now I can output my number but... what I am trying to display is an elevation angle between 0 and 90 degrees. So in my code I showed el_angle as a constant equal to 2000. So the converted_el is equal to 187.5, but since I'm usint integers it equals 187.
My LCD is actually displaying 1870, why not 187?
What I want to display is actually 18.7. Since a value of 187 is actually 18.7. I'm doing it this way so I don't have to use floating points.
How can I display 18.7 instead of 187?
Mark
PostPosted: Thu Oct 06, 2005 9:27 am     Reply with quote
Sensor wrote:
Thanks,
Hint... What does 187/10 equal?
Hint... What does 187%10 equal?
Hint... "%u.%u"
Sensor
PostPosted: Thu Oct 06, 2005 9:37 am     Reply with quote
Thanks Mark!!!
sorry for all the "beginner" questions, just learning.
Thanks again
Mark
PostPosted: Thu Oct 06, 2005 9:38 am     Reply with quote
Thanks why I didn't give you the answer. Just pushed you in the right direction.
