Pin A2 and A4 spoilt ??
Joshua Lai
PostPosted: Tue Oct 04, 2005 11:29 pm     Reply with quote
PIC 16F876, Compiler 2.734
I spent whole night, eeprom not working. Then found SDA always low.
I tested port A pin by pin using LED, and found that A2 and A4 always low, cannot output high or float.
Anyone has this problem before? Some pins spoilt and some ok? Crying or Very sad
PostPosted: Wed Oct 05, 2005 12:58 am     Reply with quote
Have you studied the description of port-A pins in the datasheet? If you did you would have discovered these pins are mixed with comparator and ADC functions. Did you disable both the comparator and analog function blocks?
Pin-A4 on most chips has an open collector output, you'll have to adjust your electronics for this.
PostPosted: Wed Oct 05, 2005 2:02 pm     Reply with quote
http://www.microchipc.com/sourcecode/images/i2c.gif
Joshua Lai
PostPosted: Wed Oct 05, 2005 10:34 pm     Reply with quote
I bought a new PIC, running the same program, everything is ok. Why?
That prove my old PIC really spoilt? But other port still working fine.
I bought PIC from fanell, what difference for 1 timer and 3 timers?
Joshua Lai
PostPosted: Wed Oct 05, 2005 10:40 pm     Reply with quote
I saw the pin diagram, I used 1k pull-up resistors.
Software i2c can use any pin right?
Mark
PostPosted: Thu Oct 06, 2005 6:14 am     Reply with quote
Umm... cause you broke it!
Joshua Lai
PostPosted: Fri Oct 07, 2005 9:33 pm     Reply with quote
Embarassed
