Memory recommendation, plz suggest |
Posted: Tue Oct 04, 2005 4:50 am |
Hi all,
In case i want to update as fast as 15 values/second, which memory type should i use. Permanent storage may not be necessary when the power goes down, since new data is readily available. Plz suggest the right memory chip. |
Posted: Tue Oct 04, 2005 5:10 am |
Why don't you use the internal RAM of the PIC? |
Re: Memory type |
Posted: Wed Oct 05, 2005 1:41 am |
Well,its a logger application, and a large amount of data needs to be stored |
Posted: Wed Oct 05, 2005 2:47 am |
Quote: | Permanent storage may not be necessary when the power goes down, since new data is readily available. |
Quote: | Well,its a logger application, and a large amount of data needs to be stored | This is a contradiction.... So what exactly do you want? Can you be a bit more specific and give us details?
You want to store 15 values/second. How many bytes per second is this? How many seconds of data do you want to store?
The more details you can provide us with the better is the response you will receive. |
kender
