Sending data over 24VDC |
Posted: Tue Oct 04, 2005 5:39 pm |
Hi !
I looking to send data to turn on relay on 24V dc 2 wires
I have only 2 wire on the building to give power to pic and photo sensor and send back data to turn on relay ?
Thanks for your help
Alain Tanguay |
Mark
Posted: Tue Oct 04, 2005 6:31 pm |
I think you need to do a little more explaination of the system.
If you want an example of a system that communicates over 2 wires and is also powered over those same wires, look at DALI |
Posted: Tue Oct 04, 2005 7:08 pm |
Yes , communication and power 24Vdc on same 2 wires |
kender
Posted: Tue Oct 04, 2005 7:11 pm |
Mark wrote: | ... look at DALI |
Mark, could you give a link to this system?
A similar problem - power and signal on one pair of wires raises, when one has to power an active antenna. It's usually solved with a bias-T. Potentially the system coud look like this:
+24V -> -> EMI
[bias-T] -> [cable]
data*clock -> -> [bias-T] -> [rectifier&filter] -> [comparator] -> data
-> +24V
Mark
APES Guest
BIAS T |
Posted: Thu Mar 23, 2006 2:04 pm |
WHat is a BIAS T
I am working on same kind of project , power and comm over power line , |
kender
Re: BIAS T |
Posted: Thu Mar 23, 2006 2:58 pm |
APES wrote: | WHat is a BIAS T |
Bias-T is essentially just one capacitor and one inductor connectd like this:
C1
modulated signal --||---------
+------------- combined power and signal
inductor |
L1 |
DC power supply ----OOOO-------
It can be used for combining DC power (or low frequency power, like 60Hz or 400Hz) with a higher frequency signa. Bias-T is typically used for providing DC power to the RF amplifiers over coax cables. |
Apes Guest
BIAS t |
Posted: Fri Mar 24, 2006 1:34 pm |
Thank for the reply
I guess we called our BIAS T a coupling ckt |
