João Paulo
| Problem to write memory |
Posted: Mon Oct 03, 2005 1:58 pm |
Please, help me ?
I have a problem when I try to write the memory eeprom. My memory is durty when 2 sensors is on.
#include <16f877.h>
#fuses HS,NOWDT,PUT
#include <input.c>
#include <stdlib.h>
#define g_pino_b7 input(pin_b7)
#define g_pino_b6 input(pin_b6)
#define g_pino_b5 input(pin_b5)
#define g_pino_b4 input(pin_b4)
#define g_pino_d7 input(pin_d7)
#define g_pino_d6 input(pin_d6)
#define g_pino_d5 input(pin_d5)
#define g_pino_d4 input(pin_d4)
/*** DECLARAÇÃO VARIAVEIS GLOBAIS ***/
short int g_flag_b7=0, g_flag_b6=0, g_flag_b5=0, g_flag_b4=0,
g_flag_d7=0, g_flag_d6=0, g_flag_d5=0, g_flag_d4=0;
/*** FUNÇÃO LIMPA ENDEREÇO DE MEMORIA ***/
void zera_memoria(int v_pista)
{ if(v_pista == 1)
{ write_eeprom(0x21,0);write_eeprom(0x22,0);write_eeprom(0x23,0);
write_eeprom(0x24,0);write_eeprom(0x25,0);write_eeprom(0x26,0);
write_eeprom(0x27,0);write_eeprom(0x28,0);write_eeprom(0x29,0);
write_eeprom(0x30,0);
else if(v_pista == 2)
{ write_eeprom(0x31,0);write_eeprom(0x32,0);write_eeprom(0x33,0);
write_eeprom(0x34,0);write_eeprom(0x35,0);write_eeprom(0x36,0);
write_eeprom(0x37,0);write_eeprom(0x38,0);write_eeprom(0x39,0);
write_eeprom(0x40,0);
else if(v_pista == 3)
{ write_eeprom(0x41,0);write_eeprom(0x42,0);write_eeprom(0x43,0);
write_eeprom(0x44,0);write_eeprom(0x45,0);write_eeprom(0x46,0);
write_eeprom(0x47,0);write_eeprom(0x48,0);write_eeprom(0x49,0);
write_eeprom(0x50,0);
else if(v_pista == 4)
{ write_eeprom(0x51,0);write_eeprom(0x52,0);write_eeprom(0x53,0);
write_eeprom(0x54,0);write_eeprom(0x55,0);write_eeprom(0x56,0);
write_eeprom(0x57,0);write_eeprom(0x58,0);write_eeprom(0x59,0);
write_eeprom(0x60,0);
/*** FUNÇÃO PRINCIPAL ***/
{ int v_qtd=0;
printf("\r\nPrograma Iniciado.");
//Seta status das portas de entradas e saidas
output_low(pin_b7); output_low(pin_b6); output_low(pin_b5); output_low(pin_b4);
output_low(pin_b3); output_low(pin_b2); output_low(pin_b1); output_low(pin_b0);
output_low(pin_d7); output_low(pin_d6); output_low(pin_d5); output_low(pin_d4);
output_low(pin_d3); output_low(pin_d2); output_low(pin_d1); output_low(pin_d0);
//Limpa memoria
zera_memoria(1);
zera_memoria(2);
zera_memoria(3);
zera_memoria(4);
//Loop Infinito
while(true)
output_high(pin_b2);
if(g_pino_b7 && !g_flag_b7 && !g_pino_d7)
{ printf("\r\n Pino B7 acionado.");
g_flag_b7=1;
v_qtd = 1 + read_eeprom(0x21);
write_eeprom(0x21,v_qtd);
printf("\r\n Variavel:%u - Memoria:%u",v_qtd,read_eeprom(0x21));
else if (g_pino_b6 && !g_flag_b6 && !g_pino_d6)
{ printf("\r\n Pino B6 acionado.");
g_flag_b6=1;
v_qtd = 1 + read_eeprom(0x22);
write_eeprom(0x22,v_qtd);
printf("\r\n Variavel:%u - Memoria:%u",v_qtd,read_eeprom(0x22));
if(g_pino_d7 && !g_flag_d7 && !g_pino_b7)
{ printf("\r\n Pino D7 acionado.");
g_flag_d7=1;
v_qtd = 1 + read_eeprom(0x23);
write_eeprom(0x23,v_qtd);
printf("\r\n Variavel:%u - Memoria:%u",v_qtd,read_eeprom(0x23));
else if (g_pino_d6 && !g_flag_d6 && !g_pino_b6)
{ printf("\r\n Pino D6 acionado.");
g_flag_d6=1;
v_qtd = 1 + read_eeprom(0x24);
write_eeprom(0x24,v_qtd);
printf("\r\n Variavel:%u - Memoria:%u",v_qtd,read_eeprom(0x24));
else if ((g_pino_b7 && g_pino_d7) && (!g_flag_d7))
{ printf("\r\n Pino B7 e D7 acionado.");
g_flag_d7=1;
write_eeprom(0x27,1);
printf("\r\n Teste :%u",read_eeprom(0x27));
v_qtd = 1 + read_eeprom(0x25);
write_eeprom(0x25,v_qtd);
printf("\r\n Variavel:%u - Memoria:%u",v_qtd,read_eeprom(0x25));
else if ((g_pino_b6 && g_pino_d6) && (!g_flag_d6))
{ printf("\r\n Pino B6 e D6 acionado.");
g_flag_d6=1;
v_qtd = 1 + read_eeprom(0x26);
write_eeprom(0x26,v_qtd);
printf("\r\n Variavel:%u - Memoria:%u",v_qtd,read_eeprom(0x26));
else if(g_pino_b5)
{ // printf("\r\n Pino B5 acionado.");
g_flag_b7=0; g_flag_b6=0; g_flag_d7=0; g_flag_d6=0; }
Joshua Lai
Posted: Mon Oct 03, 2005 11:50 pm |
| What memory? You didn't include the eeprom driver? |
João Paulo
Posted: Tue Oct 04, 2005 5:40 am |
| I use the memory insede of PIC 16F877. I need to include the memory driver ? |
Mark
Posted: Tue Oct 04, 2005 6:29 am |
| João Paulo wrote: | | I use the memory insede of PIC 16F877. I need to include the memory driver ? |
No you don't need a memory driver. The function you called is built in.
Do you know what a for loop is? CCS places the write_eeprom() inline. You whole zero memory function is way too complicated versus what it needs to be.
for(i=0x21;i<=0x60;i++)
write_eeprom(i,0);
Now in the above code, I am assuming that you made an error in that 0x30 does not come after 0x29. It should be 0x29,0x2A,0x2B....0x2F,0x30. |
