Bart
Blinking led on 18F4550 |
Posted: Mon Oct 03, 2005 2:42 pm |
Hello all,
As I changing for 16F877 to the 18F4550, I wanted to test my new pic with the blinking led test.
I changed also from ICProg to WinPic800
Programming seems to go OK, verifieing and erasing is working.
But : I don't receive the expected blink rate. Changing to another pin ( another led with another color) works.
When I meassure the freq. (with a multimeter) it is about 40 khz.
So my led is constantly on.
Tryed to play already with other xtal without any result (changed from 20 mhz to 5.0688 mhz. with same 40 khz output on pin)
Anyone an idee ?
My code :
Code: | // VERSION : 0.1.0 : blinking blue led
#include <18F4550.h>
#fuses HS,NOWDT,NOPUT,NOLVP,BROWNOUT,NOCPD,NOWRT
while (TRUE)
output_HIGH(PIN_A0);
delay_ms(10000);
output_LOW(PIN_A0);
delay_ms(10000);
_________________ I like Skype (www.skype.com), my username is BplotM |
VanHauser
Joined: 03 Oct 2005 Posts: 88 Location: Ploiesti, Romania
Posted: Mon Oct 03, 2005 3:52 pm |
Try changing the BROWNOUT fuse into NOBROWNOUT or add BORV20 fuse. Check your power supply voltage for a correct brown-out configuration. |
Humberto
Posted: Mon Oct 03, 2005 5:09 pm |
Read the data sheet. The 18F family it is not a Plug&Play device.
Itīs a complex uC plenty of modules and functions that must be configured
properly before start running.
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BROWNOUT_NOSL //Brownout enabled during operation,
disabled during SLEEP
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18)
used for I/O
#FUSES PBADEN //PORTB pins are configured as analog input channels on
RESET
#FUSES NOXINST //Extended set extension and Indexed Addressing
mode disabled (Legacy mode)
#FUSES PLL1 //No PLL PreScaler
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(VREF_LOW|-2);
setup_low_volt_detect(FALSE);
setup_oscillator(False);
while (TRUE)
output_toggle(PIN_A0);
Humberto |
Bart
Thanks for the reply's |
Posted: Wed Oct 05, 2005 2:49 pm |
Thanks for the reply's.
Problem is found : it was due to my MAX232 ic.
I think it generated to much noise on the power line.
Adding a cap between pin 15 and 16 on the MAX232 of 10uF solved the problem. _________________ I like Skype (www.skype.com), my username is BplotM |
