Georg Prinz
Joined: 07 Jan 2004 Posts: 22 Location: Frankfurt, Germany
PIC 18F4620 bug? |
Posted: Sun Oct 02, 2005 8:02 am |
Hi folks,
I started a new project with 18f4620 facing severe problem. The first chip I couldn't set the fuses. Replacing the chip by a new one, every thing seemd to be ok, the code was loaded, but nothing happened. Setting debug halts, showed that the interrupt was firing, but counter1 stucked to random value. Only the "if"-code line worked, nothing else.
I'am using PCH version 3.213 and ICD V2.12 (CCS 1.33 Rev. #97 for pic16 & pic18).
Test-Program Code: |
#include "C:\Programme\PICC\Devices\18F4620.h"
#device icd=true // Debug flag
#FUSES HS // Crystal osc highmhz
#FUSES NOWDT // No Watch Dog Timer
#FUSES NOLVP // No low voltage programing
#FUSES NOPROTECT // Code not protected from reading
#FUSES NOBROWNOUT // no Reset when brownout detected
#FUSES DEBUG // Test code to be generated
#FUSES MCLR // Master clear pin enabled
#FUSES NOCPD // No EE protection
#use delay(clock=20000000) // 20 MHz quartz
#use fast_io(c)
#use fast_io(d)
static long counter1, R;
#define Red PIN_D2
#define Green PIN_C4
#define White PIN_C2
#define Red_blink 10
#int_RTCC
RTCC_isr()
counter1 = counter1 - 1;
if(!counter1)
counter1 = Red_blink;
output_toggle(Red);
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_256);
R = Red_blink;
enable_interrupts(INT_RTCC);
do
R = R - 1;
If(!R) R = Red_blink;
} while(1);
:evil:
Any idea?
Gracias for help in andvance
Georg
_________________ dl 2 kp |
Posted: Sun Oct 02, 2005 11:19 am |
One problem is that you're using #fast_io but you never set the TRIS.
My suggestion is to comment out those lines.
// #use fast_io(c)
// #use fast_io(d)
Then the compiler will automatically set the TRIS when you use
the CCS pin functions:
output_low()
output_high()
output_toggle()
etc. |
Georg Prinz
Posted: Sun Oct 02, 2005 1:28 pm |
Thanks for replying so fast,
but I'am very sorry these lines are left from playing around. I already commented them out without any result. In the main routine the counter is not set to the start value and in the loop as well in the interrupt service routine the counter is not decremented. It is crazy.
Georg _________________ dl 2 kp |
Posted: Sun Oct 02, 2005 2:28 pm |
Quote: | In the main routine the counter is not set to the start value |
Do you mean that in the code shown below, counter1 is not set equal to 10 ?
Code: | #define Red_blink 10
R = Red_blink; |
I assume you are checking this with the CCS debugger. What happens
if you use a printf statement ? What does it display ? Example:
printf("counter1 = %LX \n\r", counter1);
Quote: | I'am very sorry these lines are left from playing around. I already commented them out without any result. |
Is the rest of the posted program accurate ? I can't really help you
unless I see the exact code that you're running.
1. If you're having weird problems, then check the "Limitations" section
for ICD2 help in MPLAB. I know you're using CCS ICD and PCWH
IDE, but some of the same limitations will still apply.
Quote: | PIC18FXX20/XX31 Limitations:
You must connect the AVDD and AVSS pins for the device to program. | (ie., connect them to Vdd and Ground -- don't leave them unconnected).
2. Also, I wonder if the Config bits are being set correctly ?
Look near the end of your .LST file, and find the section called "Configuration Fuses" and post it. |
Georg Prinz
Running!! |
Posted: Mon Oct 03, 2005 8:48 am |
I made him legs to run!
Hallo PCM Programmer,
thanks for your suggestions! After going through of all your proposals and digging in Microchips documentation I remembered reading somewhere, maybe even on this forum, that some chips shall be operated first with a lower frequency oscilator. Therefore I change the quartz to 4MHz and "Heureka!" it's running. Then I went to 10MHZ and last back to 20MHz. Not only both frequencies are working even the first chip, which I couldn't even set the fuses is running now.
Now I'am happy, but on the other side it is frustrating loosing lot of time.
Do you have a explanation about this weird behavior. I did'nt change anything in the program, except I set "NOPUT fuses", but this config bit was disabled before as standard, when no fuse-command was included.
Best Regards,
I appreciate this forum very much. I remember former times very well, sitting long nights struggling software problems without any help and any internet.
Gerog _________________ dl 2 kp |
Georg Prinz
Running!! |
Best Regards,
