gwg_1313
Playstation 2 Controller SPI Interface, Help! |
Posted: Wed Dec 01, 2004 9:14 pm |
Hello All --
Has anyone successfully interfaced with a Playstation 2 Controller with the built in CCS SPI functionality? I'm having problems establishing communications.. Any comments, sample code, interface schematics would be greatly appreciated.
Thanks,
Gary
me@garygavin.net |
Mark
Posted: Sat Dec 04, 2004 5:15 pm |
I already found that website... I was hoping someone had experince doing it via CCS SPI.
Thanks,
Gary
me@garygavin.net |
new Guest
Posted: Tue Sep 27, 2005 8:29 pm |
i have the same problem can anyone help?? |
vinicius.mecatronica
Solved |
Posted: Wed Sep 04, 2013 11:04 am |
Hi friend,
I needed the same project. I was trying to use the spi but it just got me mad. I reproduced the spi behavior moving bits and it worked.
#include <main.h>
#define lcd_rs pin_a0 // pino rs do LCD
#define lcd_enable pin_a1 // pino enable do LCD
#define lcd_d4 pin_a2 // pino de dados d4 do LCD
#define lcd_d5 pin_a3 // pino de dados d5 do LCD
#define lcd_d6 pin_a4 // pino de dados d6 do LCD
#define lcd_d7 pin_a5 // pino de dados d7 do LCD
#include "mod_lcd.c"
#define clk_ps pin_b7
#define comm_ps pin_b6
#define data_ps pin_b5
#define att_ps pin_b4
#define ack_ps pin_b3
int play (int ps_out)
int ps_in = 0;
delay_us(2);
output_low(clk_ps);
output_bit(comm_ps,bit_test(ps_out,0)); // envia saída
delay_us(2);
output_high(clk_ps);
if(input(data_ps)){bit_set(ps_in,0); } else {bit_clear(ps_in,0); } // lendo entrada
delay_us(2);
output_low(clk_ps);
output_bit(comm_ps,bit_test(ps_out,1)); // envia saída
delay_us(2);
if(input(data_ps)){bit_set(ps_in,1); } else {bit_clear(ps_in,1); } // lendo entrada
delay_us(2);
output_low(clk_ps);
output_bit(comm_ps,bit_test(ps_out,2)); // envia saída
delay_us(2);
if(input(data_ps)){bit_set(ps_in,2); } else {bit_clear(ps_in,2); } // lendo entrada
delay_us(2);
output_low(clk_ps);
output_bit(comm_ps,bit_test(ps_out,3)); // envia saída
delay_us(2);
if(input(data_ps)){bit_set(ps_in,3); } else {bit_clear(ps_in,3); } // lendo entrada
delay_us(2);
output_low(clk_ps);
output_bit(comm_ps,bit_test(ps_out,4)); // envia saída
delay_us(2);
if(input(data_ps)){bit_set(ps_in,4); } else {bit_clear(ps_in,4); } // lendo entrada
delay_us(2);
output_low(clk_ps);
output_bit(comm_ps,bit_test(ps_out,5)); // envia saída
delay_us(2);
if(input(data_ps)){bit_set(ps_in,5); } else {bit_clear(ps_in,5); } // lendo entrada
delay_us(2);
output_low(clk_ps);
output_bit(comm_ps,bit_test(ps_out,6)); // envia saída
delay_us(2);
if(input(data_ps)){bit_set(ps_in,6); } else {bit_clear(ps_in,6); } // lendo entrada
delay_us(2);
output_low(clk_ps);
output_bit(comm_ps,bit_test(ps_out,7)); // envia saída
delay_us(2);
if(input(data_ps)){bit_set(ps_in,7); } else {bit_clear(ps_in,7); } // lendo entrada
delay_us(200);
return ps_in;
//!int x=0,y=0,z=0,ang1 = 0,ang2 = 0,ang3 = 0;
int ps_in = 0, ps_out=0x01;
int ps_in2 = 0, ps_out2=0x42;
int ps_in3 = 0, ps_out3=0x00;
int ps_in4 = 0, ps_out4=0x00;
int ps_in5 = 0, ps_out5=0x00;
output_high(att_ps);
lcd_ini();
while(true)
output_low(att_ps);
ps_in = play(ps_out);
ps_in2 = play(ps_out2);
ps_in3 = play(ps_out3);
ps_in4 = play(ps_out4);
ps_in5 = play(ps_out5);
lcd_escreve ('\f'); // limpa o display
lcd_pos_xy (1, 1); // Posiciona cursor no LCD
printf (lcd_escreve, "%2X %2X %2X %2X ",ps_out,ps_in,ps_out2,ps_in2);
lcd_pos_xy (1, 2); // Posiciona cursor no LCD
printf (lcd_escreve, "%2X%2X %2X%2X %2X%2X",ps_out3,ps_in3,ps_out4,ps_in4,ps_out5,ps_in5);
//! break;
The right values to ps_out you can find in here http://store.curiousinventor.com/guides/PS2/#hardware
in this code, the values of ps_in4 and ps_in5 are the data from the buttons.
I hope I have helped.
Cheers! |
