RS232 will not start (reliably)
eyewonder300
PostPosted: Tue Sep 27, 2005 6:30 pm     Reply with quote
I am using an 18F4680 to receive GPS serial data but can not make it start up every time. The PIC board supplies ground, +12, along with TX/RX on the same cable to the GPS. If I restart the PIC with GPS on, I get no joy. I have put bit-toggle flags in the ISR to check if its even getting there, and it is not.
However, if the GPS is off when I reset the PIC, wait a few seconds, then turn on the GPS, all works as intended. Is there something I need to initialize, or otherwise set up?
As always, help is appreciated
Steve
//   fuel_gps_test_1.c   Changing to 'F4680
//   Fuel_GPS_test.c
//   This works, BUT:  if GPS quits/powers down, the system will think
//   that the last entry is still current.  Need a way to check whether
//   or not the GPS is working, and if not, set some flag, or other.
#include <18f4680.H>
//#include <16f877a.H>
#device *=16
#FUSES HS,NOPROTECT,NOWDT,NOBROWNOUT,NOLVP,NOCPD,NOWRT
#use delay(clock=10000000)
#use fast_io(e)
#include "noritake_fms_4.h"
#include "ram_address20.h"
#include <stdlib.h>
#include <math.h>
//char gps_text;
//int gps_string_pos;
//char ns_string[5];         //   4 ascii characters + null term to make it a string
//char ew_string[5];
#int_RDA
void RDA_isr(void)
 output_toggle(pin_e0);      //   flag to check entrance to this ISR
    gps_text = getc();          //   char sent from Garmin
    if (gps_text == 0x40)        // 0x40 = @, which is start of gps sentence
      gps_string_pos = 1;      //   start tracking character position
      gps_string_pos++;
   if(gps_string_pos > 41 && gps_string_pos < 46)
      switch (gps_string_pos)
         case 42: ew_string[0] = gps_text;
         case 43: ew_string[1] = gps_text;
         case 44: ew_string[2] = gps_text;
         case 45: ew_string[3] = gps_text;
   if(gps_string_pos > 46 && gps_string_pos < 51)
         case 47: ns_string[0] = gps_text;
         case 48: ns_string[1] = gps_text;
         case 49: ns_string[2] = gps_text;
         case 50: ns_string[3] = gps_text;
                misc_flag.gps_data_in = 1;
                output_toggle(pin_e1);
   vfd_init();
   vfd_putc("\f  GPS receive test");
   set_tris_e(0);
   set_tris_c(0b10100111);
   delay_ms(2000);
   gps_string_pos = 0;
   misc_flag.gps_data_in = 0;
   ns_string[4] = 0x00;         //   write the 'null' character
   ew_string[4] = 0x00;         //   write the 'null' character
   enable_interrupts(global);
   enable_interrupts(int_rda);
    output_toggle(pin_e2);
      if(misc_flag.gps_data_in == 1)      //   both data words are in
         misc_flag.gps_data_in = 0;      //   clear flag
         vfd_gotoxy(1,2);
         vfd_putc("                        ");
         vfd_gotoxy(1,2);
         temp16_1 = atol(ns_string);
         printf(vfd_putc,"%lu",temp16_1);
         vfd_gotoxy(12,2);
         temp16_2 = atol(ew_string);
         printf(vfd_putc,"%lu",temp16_2);
         temp16_1 *= temp16_1;
         temp16_2 *= temp16_2;
         temp16_1 += temp16_2;
         float_1 = temp16_1;
         float_1 /= 10;
         float_2 = sqrt(float_1);
         temp16_1 = float_2;
PostPosted: Tue Sep 27, 2005 6:39 pm     Reply with quote
Before we do any other analysis, add the ERRORS parameter
to your #use rs232 statement, as shown in bold below
cmdrdan
PostPosted: Tue Sep 27, 2005 6:45 pm     Reply with quote
In addition to PCM's advice on ERRORS, verify the GPS baud rate. Mine runs at 4800 baud, not 9600....
Dan
eyewonder300
PostPosted: Tue Sep 27, 2005 6:52 pm     Reply with quote
OK, I put the 'ERRORS' parameter in the 'use rs232' line, and it seems to work.
I looked at my CCS manual, and it just said that 'ERRORS' will save the receive errors in a variable, and then reset the error condition. This seems to work for my simple, receive-only application, unless there is something else that I should look at.
Thanks, PCM
Also, I have previously tested live reception (after the forced start-up) of the data of interest, and it appears OK
Steve
