Fast USB with PIC18F4550
prayami
PostPosted: Mon Sep 26, 2005 7:35 pm     Reply with quote
Hi..I got the latest version of the CCS compiler few weeks ago. I have
tested the example program for USB successfully.
Question: How to increase speed?
(1)
Now I want to increase the speed of sending data. On the datasheet of
PIC18F4550, it is written that its speed is 12Mb/S. Is that mean that
I can send 12000 MegaBytes/millisecond ?
In the example file "ex_usb_hid.c" following is written....
//// - On a full speed device, max polling rate is 1 transaction ////
//// per 1ms. This is 64000 bytes per second (64 byte packets ////
//// every 1ms). ////
Is that mean that, I can send only 64bytes per second?
(2)
There is code for debug on RS232. Can disable that any way or I have
modified that at all the places?
(3)
I think to send whole 8 bit array of 8 elements like that following
usb_put_packet(1, out_data, 8, USB_DTS_TOGGLE);
Is this the only possible way to make it faster?
Can anybody tell me to increase the speed all possible way? The code is
little bit complex so it is hard for me to understand.
Thanks.....
PostPosted: Mon Sep 26, 2005 8:53 pm     Reply with quote
On the datasheet of PIC18F4550, it is written that its speed is 12Mb/S.
Is that mean that I can send 12000 MegaBytes/millisecond ?
http://www.everythingusb.com/usb2/faq.htm
Mark
PostPosted: Mon Sep 26, 2005 9:47 pm     Reply with quote
You are confusing Mb (megabits) with MB (megabytes).
Regardless of all that, you aren't going to achieve a high transfer rate unless you use Isochronous Transfer were the max packet size is 1023 for full speed versus the 64 bytes.
