Foppie
Joined: 16 Sep 2005 Posts: 138 Location: The Netherlands
kbhit problem |
Posted: Fri Sep 23, 2005 4:46 am |
when I use kbhit() in my code after a printf() statement. I seem always to get TRUE as a result from kbhit(), even when I can't receive anything. Is that true, or is my code bugged? (I wrote it 4 times in different ways, but always get the same results....)
Can someone help me?
Code: | #device PIC16F877A *=16 ADC=10
#include <drivers/16f877.h>
#FUSES HS //High speed Osc (> 4mhz)
#FUSES NOLVP //Low Voltage Programming on B3
#use rs232(baud=9600, parity=n, bits=8, xmit=PIN_C6, rcv=PIN_C7, errors, stream=UWEAVE)
short checknetwork(int try)
// Input : void
// Output : short - connected to network(1) or not connected(0)
// Action : connects to network
short result, connected;
int i;
char data[80];
i = 0;
result = FALSE;
connected = FALSE;
lcd_gotoxy(1,1);
printf(lcd_putc, "\fConnecting...");
lcd_gotoxy(1,2);
printf(lcd_putc, "try: %u", try);
puts("ATE?");
for(i = 0; ((i <= 79) && (!result)); i++)
while(!kbhit()) delay_us(10);
data[i]=getc();
if (i > 1)
if ((data[i - 1] == 'O') && (data[i] == 'K'))
result = TRUE;
connected = TRUE;
if (i > 4)
if ((data[i - 4] == 'E') && (data[i - 3] == 'R') && (data[i - 2] == 'R') && (data[i - 1] == 'O') && (data[i] == 'R'))
result = TRUE;
lcd_gotoxy(1,1);
printf(lcd_putc, "\fdata: ", data);
delay_ms(2000);
return connected;
lcd_init();
//establish connection
while(!checknetwork(i++));
Posted: Fri Sep 23, 2005 11:42 am |
My suggestion is, get rid of all the parsing code and write a small test
program. i.e., no more than 6 lines of code inside main().
If you can demonstrate the error, then post that program and also
post the version of your compiler. |
Foppie
Posted: Mon Sep 26, 2005 2:49 am |
I now have it working using an interrupt.
Thanks for the advice to make a small test program first. I think I just wanted to much in once... |
