Markdem
Quick timer program problem |
Posted: Fri Sep 23, 2005 8:14 am |
Hi All, i am tring to write a very simple timer program, but am having some problems. It is ment to turn on a relay when i press and hold a buttion, and the delay the turnoff but some time (2 seconds in this example). This all works ok, however, if i repress the buttion within the timout priod it will not delay when i let go again. It will just stay on as long as i hold the buttion, but will turn off as soon as i let go. If i let the relay turn off before pushing the buttion, it will work OK.
My code is below
Thank you for your help
Mark
#include <12F629.h>
#fuses NOWDT,INTRC_IO, NOCPD, NOPROTECT, NOMCLR, NOPUT, BROWNOUT
OUTPUT_low(pin_A0); //make sure blower is off
while (input(pin_A2)); //Wait untill buttion is pressed
output_low(pin_a0);
while (!input(pin_A2)); //turn blower on if buttion is pressed
output_high(pin_a0);
delay_ms(2000);
Mark
Posted: Fri Sep 23, 2005 8:37 am |
You put ';' after the while statements. This is what your code actually looks like:
Code: | #include <12F629.h>
output_low(pin_A0); //make sure blower is off
output_low(pin_a0);
delay_ms(2000);
This is what you probably want
// Blower off
output_low(pin_a0);
// Wait until button is pressed
// Blower on
// 2 second delay after button release
while (delaycount < 2000)
delay_ms(1);
// Keep delaying until button is released
if (!input(pin_A2))
delaycount = 0
delaycount++;
