Multiply/Divide Problems ccs 3.124
Steve Elliott
PostPosted: Tue May 27, 2003 10:58 am     Reply with quote
Having trouble using multiply and divide on ccs 3.124 with pic16f876 (MPLAB 5.7). The object code that is generated is missing the multiply and divide stubs.
here's sample code:
#include <16F876.H>
main ()
int a;
int b;
a = 1200;
b = 12*a;
generates:
CCS PCM C Compiler, Version 3.124, 16648
Filename: C:\BK\KEYERS\K45C\TEST.LST
ROM used: 60 (1\%)
Largest free fragment is 2048
RAM used: 7 (4\%) at main() level
9 (5\%) worst case
Stack: 1 locations
0000: MOVLW 00
0001: MOVWF 0A
0002: GOTO 02B
0003: NOP
.................... #include <16F876.H>
.................... //////// Standard Header file for the PIC16F876 device ////////////////
.................... #device PIC16F876
.................... #list
.................... main ()
.................... int a;
.................... int b;
002B: CLRF 04
002C: MOVLW 1F
002D: ANDWF 03,F
002E: MOVLW 07
002F: BSF 03.5
0030: MOVWF 1F
0031: BCF 03.5
.................... a = 1200;
0032: MOVLW B0
0033: MOVWF 21
.................... b = 12*a;
0034: MOVLW 0C
0035: MOVWF 23
0036: MOVF 21,W
0037: MOVWF 24
0038: GOTO 004
0039: MOVF 78,W
003A: MOVWF 22
003B: SLEEP
That is all the code that gets generated.
Notice that there is a jump to the multiply handler at address 004 but there is nothing present at 004, it wasn't included by the complier !!
Am I missing an include file ?
___________________________
Original Post ID: 144514786
davidpk
Re: Multiply/Divide Problems ccs 3.124
PostPosted: Tue May 27, 2003 11:14 am     Reply with quote
An int variable is limited to 0-255, both 1200 and 12*1200 are too large for the variables. Try the 'long' variable type.
:=Having trouble using multiply and divide on ccs 3.124 with pic16f876 (MPLAB 5.7). The object code that is generated is missing the multiply and divide stubs.
:=here's sample code:
:=#include <16F876.H>
:=main ()
:= int a;
:= int b;
:= a = 1200;
:= b = 12*a;
:=generates:
:=CCS PCM C Compiler, Version 3.124, 16648
:= Filename: C:\BK\KEYERS\K45C\TEST.LST
:= ROM used: 60 (1\%)
:= Largest free fragment is 2048
:= RAM used: 7 (4\%) at main() level
:= 9 (5\%) worst case
:= Stack: 1 locations
:=0000: MOVLW 00
:=0001: MOVWF 0A
:=0002: GOTO 02B
:=0003: NOP
:=.................... #include <16F876.H>
:=.................... //////// Standard Header file for the PIC16F876 device ////////////////
:=.................... #device PIC16F876
:=.................... #list
:=.................... main ()
:=.................... int a;
:=.................... int b;
:=002B: CLRF 04
:=002C: MOVLW 1F
:=002D: ANDWF 03,F
:=002E: MOVLW 07
:=002F: BSF 03.5
:=0030: MOVWF 1F
:=0031: BCF 03.5
:=.................... a = 1200;
:=0032: MOVLW B0
:=0033: MOVWF 21
:=.................... b = 12*a;
:=0034: MOVLW 0C
:=0035: MOVWF 23
:=0036: MOVF 21,W
:=0037: MOVWF 24
:=0038: GOTO 004
:=0039: MOVF 78,W
:=003A: MOVWF 22
:=003B: SLEEP
:=That is all the code that gets generated.
:=Notice that there is a jump to the multiply handler at address 004 but there is nothing present at 004, it wasn't included by the complier !!
:=Am I missing an include file ?
Original Post ID: 144514787
Steve Elliott
PostPosted: Tue May 27, 2003 12:33 pm     Reply with quote
:=An int variable is limited to 0-255, both 1200 and 12*1200 are too large for the variables. Try the 'long' variable type.
hmmm.... same thing...
#include <16F876.H>
main ()
long a;
long b;
a = 1200;
b = 12*a;
generates:
0000: MOVLW 00
0001: MOVWF 0A
0002: GOTO 01B
0003: NOP
.................... long a;
.................... long b;
001B: CLRF 04
001C: MOVLW 1F
001D: ANDWF 03,F
001E: MOVLW 07
001F: BSF 03.5
0020: MOVWF 1F
0021: BCF 03.5
0022: MOVLW 04
0023: MOVWF 22
0024: MOVLW B0
0025: MOVWF 21
0026: CLRF 26
0027: MOVLW 0C
0028: MOVWF 25
0029: MOVF 22,W
002A: MOVWF 28
002B: MOVF 21,W
002C: MOVWF 27
002D: GOTO 004
002E: MOVF 79,W
002F: MOVWF 24
0030: MOVF 78,W
0031: MOVWF 23
0032: SLEEP
Original Post ID: 144514788
Steve Elliott
PostPosted: Tue May 27, 2003 1:46 pm     Reply with quote
Ok, sorry for the bandwidth, the code is there in the hex file it is just not included in the MPLAB .lst file. It is odd to step through the code and see it get frozen on the goto line while it is executing code "that isn't there". But is does come back magically with the correct calculated value.
I'm guessing it's protected code, hidden to protect IP ?
Original Post ID: 144514790
R.J.Hamlett
PostPosted: Tue May 27, 2003 1:47 pm     Reply with quote
:=main ()
:= int a;
:= int b;
:= a = 1200;
:= b = 12*a;
:=generates:
:=0000: MOVLW 00
:=0001: MOVWF 0A
:=0002: GOTO 02B
:=0003: NOP
:=002B: CLRF 04
:=002C: MOVLW 1F
:=002D: ANDWF 03,F
:=002E: MOVLW 07
:=002F: BSF 03.5
:=0030: MOVWF 1F
:=0031: BCF 03.5
:=0032: MOVLW B0
:=0033: MOVWF 21
:=0034: MOVLW 0C
:=0035: MOVWF 23
:=0036: MOVF 21,W
:=0037: MOVWF 24
:=0038: GOTO 004
:=0039: MOVF 78,W
:=003A: MOVWF 22
:=003B: SLEEP
There is nothing wrong with the code...
The compiler does not generate assembler, in the list file for these routines, by default. The code is sitting there, between 0004, and 002B. If you look at the hex file, or import it into MPLAB, you will see the code is there.
If you want to see it, edit the start of the 16F876.h file, and change the third line (which normally reads #nolist), and remark this out as //#nolist). Recompile, and the code will be displayed.
Original Post ID: 144514791
PostPosted: Tue May 27, 2003 2:11 pm     Reply with quote
:=Ok, sorry for the bandwidth, the code is there in the hex file it is just not included in the MPLAB .lst file. It is odd to step through the code and see it get frozen on the goto line while it is executing code "that isn't there". But is does come back magically with the correct calculated value.
You can see the code if you go to the Window/Program Memory
menu in MPLAB.
Original Post ID: 144514792
Michael Thompson
PostPosted: Wed May 28, 2003 8:35 am     Reply with quote
:=main ()
:= int a;
:= int b;
:= a = 1200;
:= b = 12*a;
:=generates:
:=0000: MOVLW 00
:=0001: MOVWF 0A
:=0002: GOTO 02B
:=0003: NOP
:=002B: CLRF 04
:=002C: MOVLW 1F
:=002D: ANDWF 03,F
:=002E: MOVLW 07
:=002F: BSF 03.5
:=0030: MOVWF 1F
:=0031: BCF 03.5
:=0032: MOVLW B0
:=0033: MOVWF 21
:=0034: MOVLW 0C
:=0035: MOVWF 23
:=0036: MOVF 21,W
:=0037: MOVWF 24
:=0038: GOTO 004
:=0039: MOVF 78,W
:=003A: MOVWF 22
:=003B: SLEEP
R.J. is correct in that the code for the multiply routine at 004 will only be in the list file if the #nolist in the pic16f876.h file is commented out or removed.
Try a = 1200L; to ensure that the constant is typed to that of a long.
Regards,
Mike
Original Post ID: 144514812
