10F206 comparator with int voltage reference not working??
spero
PostPosted: Thu Sep 22, 2005 12:23 pm     Reply with quote
Has anyone successfully used the 10F206 comparator using the internal voltage reference (0.6V) as the negative reference for the comparator? I cannot get the comparator to change the CMPOUT bit to 0.
I'm trying to implement a cheap and nasty battery low detect as follows;
When the battery falls to its cutoff level, a resistive potential divider will present 0.6V at the CIN+ pin (GP0). The negative reference of the comparator is setup to use the internal voltage reference.
My code to setup and read the comparator output bit is as follows;
#bit CMPOUT = 0x07.7
#bit CMPON = 0x07.3
#asm // Setup and enable comparator - load CMCON0 reg
movlw 0xFB
movwf 0x07
#endasm
delay_us(1); // Let comparator stabilise before reading
if(CMPOUT == 0)
bat_low = TRUE; // If Vin+ < Vin- then set flag
output_high(PIN_B2);
CMPON = 0; // Disable comparator before going to sleep
set_tris_b(0x09); // Set TRIS again after comparator has fiddled with them...
sleep();
Cheers,
Spero.
mcafzap
PostPosted: Fri Sep 23, 2005 6:23 am     Reply with quote
Without referring to the datasheet, here is a section of my code, where I set the comparator voltage to about half rail. I also put the thing to sleep to save power - hence no 'While (1)'.
#byte CMCON0 = 0x07
#bit GP0= GPIO.0     //comparator input
#bit CMPOUT = CMCON0.7
#bit CMPON = CMCON0.3
#asm
   movlw 0x09  //Bits 0 & 3 inputs
   TRIS GPIO
// Disable wake-up on pin change, enable weak pull-ups,
// Timer0 source internal, L to H
// Prescaler to WDT, max division 2304mS
   movlw 0x8F
   OPTION
#endasm
// no comparator output,
   CMCON0 = 0x73;
      nofield = 0;
      alert_on = 0;
      sleepcount=0;
//   while (1) {
      CMPON = 1;        // Turn on Comparator
      if (CMPOUT){            // Triggered
         CMPON = 0;
etc.
PostPosted: Fri Sep 23, 2005 8:37 am     Reply with quote
Thanks...I found my problem; I had a == instead of a = and my flag was never being set, so the comaparator was working all the time!
