Soft UART
cstan_02
Soft UART
PostPosted: Wed Sep 21, 2005 8:43 pm     Reply with quote
#case
#if defined(__PCM__)
   #include <12F675.h>
#DEVICE ADC=10
#fuses   XT,NOWDT,MCLR,PUT
#use  delay(clock=4000000,restart_wdt)
#use  rs232(baud=9600, xmit=PIN_A1,rcv=PIN_A0, parity=N, bits=8, stream=COM3, DISABLE_INTS,BRGH1OK)
#priority   ra,rtcc
#use fast_io(A)
static short read_adc_vlu;
#int_ra
void uart_isr() {
char c;
c=fgetc(COM3);
switch(c){
      case 0x55:
         fputc(c,COM3);        // If i disable this line and/or put some delay instead, it won't work. why??
         read_adc_vlu=TRUE;
      default:
system_init();
if (read_adc_vlu)   {printf("%ld\n\r", read_adc());read_adc_vlu = FALSE;}   // read_adc_vlu flag is set in the interrupt routine
 }//End the while loop!!
// Function declarations
void system_init(void)
set_tris_a(0b100001);
setup_adc_ports(sAN2);
set_adc_channel(2);
 int_count = INTS_PER_SECOND;
   set_timer0(0);
   setup_counters(RTCC_INTERNAL, RTCC_DIV_256 | RTCC_8_BIT);
  enable_interrupts(INT_RTCC);
//                 rtcc routine is not shown here as it does'nt matters!!
   enable_interrupts(INT_RA0);
Why is this that, when i don't send out a character everytime i receive one, it won't work? Tried adding delays instead, but won't budge. (compiler's the latest one!!)
Thanks.
-cstan
Your Mind Is Your Biggest Asset !!
PostPosted: Thu Sep 22, 2005 1:55 am     Reply with quote
I suspect your problem has something to do with the use of the interrupt on the A0 pin. This interupt has some strange side effects, for example the interrupt flag is cleared on every read/write of GPIO. You would make life a lot easier on yourself by using the INT pin (A2) instead of A0.
cstan_02
Soft UART
PostPosted: Thu Sep 22, 2005 6:56 am     Reply with quote
Thanks ckielstra, I'll try with the EXT on A2.
-cstan
