RS232 with variable bytes to recieve
cam_male2003
PostPosted: Wed Sep 21, 2005 11:49 am     Reply with quote
My code only receives two bytes or 2 Hex Characters. Ideas? I am trying to receive various amounts of data. Rolling Eyes Rolling Eyes
void recv()
   for(i=0;i<=127;i++)
         if(kbhit())
            buffer[i]=getc();
            print_value(i*2,buffer[i]);  //used to show the hex code on my screen
            restart_wdt();
PostPosted: Wed Sep 21, 2005 12:06 pm     Reply with quote
This is a common error for people new to serial communications in the PIC processor. The hardware UART can buffer up to two characters before it reaches an buffer overflow condition and stalls, so make sure your program is fast enough to read all incomming data.
A printf command in a serial receive routine is a tricky thing as the transmission of a single byte takes an equal time to receiving a new byte. From your comments I understand you are showing the hex value, this takes at least two bytes. In the time you receive a single byte you want to transmit two bytes which is impossible.
To get the UART out of the error situation add the ERRORS keyword to the #use RS232 clause. You will still loose data but don't lock up anymore.
cam_male2003
I will try that
PostPosted: Wed Sep 21, 2005 12:28 pm     Reply with quote
I will add error to my code.. and not print until all the data is received..
Smile
asmallri
PostPosted: Wed Sep 21, 2005 3:40 pm     Reply with quote
if Recv() is not an interrupt handler then you have another problem. Assume you receive a character every millisecond. The first time through the loop you find a character so it gets put at buffer[0]. The time taken to get thru the loop is 0.8ms. The next time thru the loop (i now = 1) kbhit() returns false. We are now 1.6ms in from the first character. A new character is received. When we call kbhit() the next character is put in buffer[2]. The problem is that buffer[1] did not have anything written to it.
Regards, Andrew
Mark
PostPosted: Wed Sep 21, 2005 6:25 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=19306
