other ports with lcd.c driver?
Goto page 1, 2  Next
Foppie
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Mon Sep 19, 2005 1:50 am     Reply with quote
I need a rewritten lcd.c display driver because I use other pins on my PIC16F877A so I was searching the board but couldn't find one. So I have rewritten my own driver but it doesn't seem to work. Can someone tell me if there are any problems in my code (and where they are offcourse Wink )
rewritten lcd.c driver:
[edit]see lower post[/edit]
Maincode:
Foppie
PostPosted: Mon Sep 19, 2005 3:37 am     Reply with quote
forgot to mention that I use a HD44780A00 lcd that should be compatible with the standard lcd.c driver.
Mark
PostPosted: Mon Sep 19, 2005 9:29 am     Reply with quote
Did you not find this one?
http://www.ccsinfo.com/forum/viewtopic.php?t=20182
PostPosted: Mon Sep 19, 2005 11:41 am     Reply with quote
Hi
try to learn from this example project.
LCD Thermometer
I think you can modify that code as well.
Foppie
PostPosted: Tue Sep 20, 2005 1:24 am     Reply with quote
yes, I saw that one, but if I'm not wrong one cannot use that code when datapins are connected as following (just an example)
RD3 = DB7;
RD6 = DB6;
RD5 = DB5;
RA4 = DB4;
Can someone tell me if I am wrong or not (and why)?
P.S. I know my code can't do that to because of the set_tris_d() that got called 2 times in my code, but I'm still working on that.
Foppie
PostPosted: Tue Sep 20, 2005 5:59 am     Reply with quote
Worked it out. This might not be the most efficient, but according to my logics it works. The driver does still the same though. Sad It still doesn't work.
here my new lcd.c driver:
//define pins
#define ENABLE          PIN_E2
#define RS         PIN_E0
#define RW         PIN_E1
#define DB7         PIN_D0
#define DB6         PIN_D1
#define DB5         PIN_D2
#define DB4         PIN_D3
//TRIS registers
#define trsdb7addr      0x88
#define trsdb7bit      7
#define trsdb6addr      0x88
#define trsdb6bit      6
#define trsdb5addr      0x88
#define trsdb5bit      5
#define trsdb4addr      0x88
#define trsdb4bit      4
#define lcd_type      2      // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two   0x40      // LCD RAM address for the second line
byte CONST LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
//These bytes need to be sent to the LCD to start it up
void lcd_send_nibble(byte n)
   if (0b00001000 & n)
      output_high(DB7);
      output_low(DB7);
   if (0b00000100 & n)
      output_high(DB6);
      output_low(DB6);
   if (0b00000010 & n)
      output_high(DB5);
      output_low(DB5);
   if (0b00000001 & n)
      output_high(DB4);
      output_low(DB4);
   delay_cycles(1);
   output_high(ENABLE);
   delay_us(2);
   output_low(ENABLE);
void lcd_set_tris(short on)
   if (on)
      #asm
         BSF trsdb7addr,trsdb7bit
         BSF trsdb6addr,trsdb6bit
         BSF trsdb5addr,trsdb5bit
         BSF trsdb4addr,trsdb4bit
      #endasm
      #asm
         BCF trsdb7addr,trsdb7bit
         BCF trsdb6addr,trsdb6bit
         BCF trsdb5addr,trsdb5bit
         BCF trsdb4addr,trsdb4bit
      #endasm
int lcd_read_nibble()
   int result = 0;
   result += (8 * input(DB7));
   result += (4 * input(DB6));
   result += (2 * input(DB5));
   result += input(DB4);
   return (result);
byte lcd_read_byte()
   byte low, high;
   lcd_set_tris(1);
   output_high(RW);
   delay_cycles(1);
   delay_cycles(1);
   high = lcd_read_nibble();
   output_low(ENABLE);
   delay_cycles(1);
   delay_us(1);
   low = lcd_read_nibble();
   output_low(ENABLE);
   lcd_set_tris(0);
   return ((high << 4) | low);
void lcd_send_byte(short address, byte n)
   output_low(RS);
   while (bit_test(lcd_read_byte(), 7)) ;
   if (address)
      output_high(RS);
      output_low(RS);
   delay_cycles(1);
   output_low(RS);
   delay_cycles(1);
   output_low(ENABLE);
   lcd_send_nibble(n >> 4);
   lcd_send_nibble(n & 0xf);
void lcd_init()
   byte i;
   lcd_set_tris(0);
   output_low(RS);
   output_low(RW);
   output_low(ENABLE);
   delay_ms(15);
   for(i = 1; i <= 3; ++i)
      lcd_send_nibble(3);
      delay_ms(5); //minimum waiting time 4.1 ms
   lcd_send_nibble(2);
   for(i = 0; i <= 3; ++i)
      lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy(byte x, byte y)
   byte address;
   if(y != 1)
      address = lcd_line_two;
      address=0;
   address += x - 1;
   lcd_send_byte(0,0x80 | address);
void lcd_putc(char c)
   switch (c) {
     case '\f': //clear display
      lcd_send_byte(0,1);
      delay_ms(2);
     case '\n': //newline
      lcd_gotoxy(1,2);
     case '\b': //backspace
      lcd_send_byte(0,0x10);
     default:
      lcd_send_byte(1,c);
char lcd_getc(byte x, byte y)
   char value;
   lcd_gotoxy(x, y);
   output_high(RS);
   value = lcd_read_byte();
   output_low(RS);
   return (value);
Mark
PostPosted: Tue Sep 20, 2005 6:23 am     Reply with quote
RD3 = DB7;
RD6 = DB6;
RD5 = DB5;
RA4 = DB4;
Why on earth would someone want to connect it that way anyways!! On a 40pin PIC I find it hard to believe that one could not put the four data pins in sequence.
Foppie
PostPosted: Tue Sep 20, 2005 6:40 am     Reply with quote
Very true, but I have not build nor developed the circuit. But on the board on which I'm developing they are in sequence.
But what I really want to know is if the driver I wrote should work or not, I am not able to print anything on the LCD. Not with my driver and also not with the driver of Mark. I get the same output with both drivers, all blancs. So I suspect there is somewhere else something wrong, but on a testboard that code works so it should be in the driver...
Anyway, I am very puzzled, can someone give me a tip on what I am doing wrong?
the driver I use can be found 1 posts below, and here is the other code:
[edit]see below for updated code[/edit]
Foppie
minor changes, now it's a little bit working...
PostPosted: Wed Sep 21, 2005 1:18 am     Reply with quote
After testing and rewriting, I got the code displaying something, but it looks as if it's scrambled.
I am now using Marks lcdd.c because I thought it's safer to begin with a driver that is known working. (To many rewritten parts in my own code)
When I tested I got (finally) something on screen but now it's scrambled as following:
I send:
"Hello,"
"World!"
and I see on screen:
elo,
ord!
What am I now doing wrong?
the main code:
#device PIC16F877A *=16 ADC=8
#include <drivers/16f877.h>
#FUSES NOWDT       //No Watch Dog Timer
#FUSES HS       //High speed Osc (> 4mhz)
#FUSES NOPROTECT    //Code not protected from reading
#FUSES NOLVP       //Low Voltage Programming on B3
#FUSES NOCPD       //No EE protection
#FUSES NOWRT       //Program memory not write protected
#use rs232(baud=9600, BRGH1OK, parity=n, bits=8, xmit=PIN_C6, rcv=PIN_C7)
#include "drivers/lcd.c"
void testLcd()
   LCD_clear();
       lcd_gotoxy(1,1);
     printf(lcd_putc,"Hello,");
     lcd_gotoxy(1,2);
   printf(lcd_putc,"World!");
   while(1) ;
     testLcd();
the lcd.c driver:
struct lcd_pin_map
  int unusedA;         // portA is not used
  int unusedB;         // portB is not used
  int unusedC;         // portC is not used
  int data    : 4;      // upper nibble of portD is used for data lines
  int unusedD  : 4;      // The rest of portD
  BOOLEAN rs;         // PinE0
  BOOLEAN rw;         // PinE1
  BOOLEAN enable;          // PinE2
} lcd;
#locate lcd = 5
struct lcd_tris_map
  int control  : 3;
} lcdtris;
#locate lcdtris = 0x85
#define set_tris_lcd(x) lcdtris.data = (x); lcdtris.control = 0;
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
                             // These bytes need to be sent to the LCD
                             // to start it up.
                             // The following are used for setting
                             // the I/O port direction register.
#define LCD_WRITE    0       // For write mode all pins are out
#define LCD_READ     15      // For read mode data pins are in
BYTE lcd_read_byte() {
      BYTE low,high;
      set_tris_lcd(LCD_READ);
      lcd.rw = 1;
      delay_cycles(1);
      lcd.enable = 1;
      delay_cycles(1);
      high = lcd.data;
      lcd.enable = 0;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(1);
      low = lcd.data;
      lcd.enable = 0;
      set_tris_lcd(LCD_WRITE);
      return( (high<<4) | low);
void lcd_send_nibble( BYTE n ) {
      lcd.data = n;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(2);
      lcd.enable = 0;
void lcd_send_byte( BYTE address, BYTE n ) {
      lcd.rs = 0;
      while ( bit_test(lcd_read_byte(),7) ) ;
      lcd.rs = address;
      delay_cycles(1);
      lcd.rw = 0;
      delay_cycles(1);
      lcd.enable = 0;
void lcd_init() {
    BYTE i;
    lcd.rs = 0;
    lcd.rw = 0;
    lcd.enable = 0;
    delay_ms(15);
    for(i=1;i<=3;++i) {
       lcd_send_nibble(3);
       delay_ms(5);
    lcd_send_nibble(2);
    for(i=0;i<=3;++i)
void lcd_gotoxy( BYTE x, BYTE y) {
   BYTE address;
   if(y!=1)
     address=lcd_line_two;
     address=0;
   address+=x-1;
   lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
   switch (c) {
     case '\f'   : lcd_send_byte(0,1);
                   delay_ms(2);
     case '\n'   : lcd_gotoxy(1,2);        break;
     case '\b'   : lcd_send_byte(0,0x10);  break;
     default     : lcd_send_byte(1,c);     break;
char lcd_getc( BYTE x, BYTE y) {
   char value;
    lcd_gotoxy(x,y);
    lcd.rs=1;
    lcd.rs=0;
    return(value);
Foppie
PostPosted: Wed Sep 21, 2005 4:48 am     Reply with quote
I fixed my problem! Very Happy
There needed to be a delay in the lcd_send_byte() method. My only remaining question is: why do I need a delay when somebody else doesn't?
the modified code:
      lcd.rs = 0;
      lcd.rs = address;
      delay_cycles(1);
      lcd.rw = 0;
      delay_cycles(1);
      lcd.enable = 0;
      delay_ms(10); // <<=========== I have put this line in!!!
Mark
PostPosted: Wed Sep 21, 2005 6:23 am     Reply with quote
You shouldn't need the delay. The code is the CCS standard LCD driver which tons of people use. I only modified the variable declarations to allow different ports to be used.
Foppie
PostPosted: Wed Sep 21, 2005 6:32 am     Reply with quote
Well, I need it, If there is not an delay_us(15) or larger delay, the output gets scrambled. But maybe it's a hardware problem.
There are also LEDs connected to the dataports, could that be a problem? (I don't know much about electronics Embarassed , but I try to learn a bit)
In either case, it is working now, so Thanks for all your help
Mark
PostPosted: Wed Sep 21, 2005 6:37 am     Reply with quote
Anything connected that is affecting the signals (like rise/fall time) could certainly cause problems. However, where you inserted the delay, I would think that the problem is more likely on the control lines.
Foppie
PostPosted: Wed Sep 21, 2005 6:44 am     Reply with quote
There is nothing connected on the control lines... The only things are those LEDs with a resistor. They are connected as following:
PIN_D1
|--------[resistor 330R]----(LED)-------GND
DB6
At first I didn't think this would be a problem, but now I think this was my problem...
Foppie
scrambled readings :S
PostPosted: Thu Sep 22, 2005 2:57 am     Reply with quote
I'm running into some new trouble with the driver. As soon as I call the lcd_read_byte() or lcd_getc() method, I get scrambled data. I assume this also has something to do with the LEDs connected to the Datalines, but I don't know how to solve the problem. I tried delays (20ms) on many places in those 2 function, but it doesn't solve my problem.
Anybody any idea for how to solve the problem?
Goto page 1, 2  Next
Page 1 of 2
