static variables and multiple .c files
Simon
PostPosted: Tue Sep 20, 2005 6:01 pm     Reply with quote
I have been searching through the forums and I am aware that you cannot link multiple .c files, you have to #include them.
What I am wondering is how this affects the ability to use the static key word. I would like to create device drivers and some state machines which would be split into multiple .c files, and there is the possibility that I need "file specific static globals". I don't want them to be referenced outside of the device driver, and I don't want to have to trawl through my libraries to ensure that I haven't used a duplicate variable name...
Can I achieve this? I figure I can't but thought I would ask.
Thanks,
Simon
PostPosted: Tue Sep 20, 2005 6:17 pm     Reply with quote
Because it's essentially one big file, you don't have to worry about
having duplicate variable names by mistake. Any duplicate names will
be flagged with as an error when you compile the code. ie:
"Identifier is already used in this scope"
Simon
PostPosted: Wed Sep 21, 2005 12:53 am     Reply with quote
Thanks, I figured as much... still a very unsatisfactory way of doing things because when someone else uses the code they have access to variables they are not supposed to be using...
Mark
PostPosted: Wed Sep 21, 2005 6:47 am     Reply with quote
Limit the use of globals. If you must use one, then you can reserve a memory location and access the variable as though it were a pointer
#reserve 0x40
#define myvar *0x40
myvar = 20;
