trouble with serial input data
John Morley
PostPosted: Mon Sep 19, 2005 9:59 am     Reply with quote
Hi all,
I have a number of PIC modules interconnected using an RS485 network. Each module has a unique address assigned by a set of DIP switches, and controls two digital output lines. I am sending the following command string to the modules:
#NX:A,B<CR> where X is the module address (0 to 9), and A and B are the desired digital output states.
At this point I'm just trying to see if I can uniquely command a specific module. My code contains a serial interrupt routine that fills a receive buffer until a CR is received, and then the Main() routine checks for an address match in the received data. I know the CR is being received because I toggle one of the digital outputs (they are connected to LEDs) as a diagnostic, but the address test that follows is never successful....... A putc() of the module address returns an unprintable ASCII character. I think this is just a problem with how the data is represented in the receive buffer. I have a routine (gethexbyte) to handle that, but using it doesn't seem to help the problem. I don't think this is a hardware issue because I have a small test program that uses getc() and putc() to receive and transmit characters. Any one of the modules connected individually works fine.
My compiler version is: 3.162
//-----< Include Files, setup fuses >-----
#include <16f73.h>
#fuses HS, NOWDT, NOPROTECT
//-----< Compiler use statements >-----
// Tell compiler clock speed is 20.00 MHZ Crystal
//-----< General Program Defines >-----
#define RS232_OUT PIN_A4       // RS232 Output to Terminal
#define RS485_OUT PIN_C6       // RS485 Output Pin
#define RS485_IN PIN_C7       // RS485 Input Pin
#define RS485_Enable PIN_C5    // RS485 Enable Pin
#define Relay1_Out Pin_B0       // Relay 1 Output (active hi, and inverted by output FET)
#define Relay2_Out Pin_B1       // Relay 2 Output (active hi, and inverted by output FET)
//-----< Firmware Version >-----
#define SW_Data1 PIN_C0
#define SW_Data2 PIN_C1
#define SW_Data3 PIN_C2
#define SW_Data4 PIN_C3
#define SW_Data5 PIN_C4
#define CR         0x0d      // ASCII Value for a Carriage Return
//-----< Serial Port Definition >-----
#use rs232(baud=9600, xmit=RS232_Out, stream = Console, Restart_WDT, ERRORS)
#use rs232(baud=9600, xmit=RS485_Out, rcv=RS485_In, enable = RS485_Enable, stream = Network, Restart_WDT, ERRORS)
//-----< RS232 Packet definitions >-----
int RX_Command_Ready;      // TRUE If a receive packet is ready
#define RX_SIZE 20         // RS485 buffer for serial reception
char RxBuffer[RX_SIZE];    // RS485 serial RX buffer
int Index = 0;           // RS485 RX data IN index
int iAddress;
//-----< Get a RS232 command packet >-----
// Note: This routine is interrupt driven. RS485 input takes priority
// over every other operation in the system.
#INT_RDA   // Interrupt driven RS485 routine
void rs485_isr(void)
   char temp;   // local data storage
   temp = fgetc(Network);   // get rx data
   // If we got a CR, then the command is completed.
   if (temp == CR)
         RxBuffer[Index] = temp;
         RX_Command_Ready = TRUE;
         return;
   // Save the character to the receive buffer.
   RxBuffer[Index]=temp;
   // Check for buffer overflow.
   if ( Index >= (RX_SIZE - 1) )
      Index = 0;
      Index++;
// This routine is used to convert characters for checking the checksum
// It simply converts an ASCII hex value into true decimal form
// ASCII allows for a quick and dirty conversion routine!
byte gethexbyte(char digit) {
   if(!BIT_TEST(digit,6))      // Its a number if bit 6 is 0
      return(digit & 0x0F);   // Simple way to convert 0-9
      return((digit & 0x0F) + 9);
   // Here we read the DIP switch to determine the module network address
   iAddress= input(SW_Data1) + ( 2 * input(SW_Data2)) + (4 * input(SW_Data3)) + (8 * input(SW_Data4)) + (16 * input(SW_Data5));
   //fPrintf(Network, "Address: %d\n\r",iAddress);
   // Here we set the initialize program variables.....
   Output_low(Relay1_Out);
   Output_low(Relay2_Out);
   setup_adc_ports( NO_ANALOGS );
   enable_interrupts(INT_RDA);
      // Here we wait for a character to show up in the Rcv buffer, and then read the received string
      if ( RX_Command_Ready == TRUE )
         // Just to be safe, first things first...
         disable_interrupts(GLOBAL);
         RX_Command_Ready = FALSE;
         Output_high(Relay1_Out);   //turn on the LED so we know we received a command...
         putc(RxBuffer[2], Network);
         // Let's start to decode the command if we have the correct address.....
         if (gethexbyte(RxBuffer[2]) == iAddress)
            Output_high(Relay2_Out);
            // fprintf(Network, "#N%d:0,0,1234!", iAddress);
            // decode_command();
         // Done so re-enable RS485
         Index = 0;
   } // while
} // end Main
Does anyone have an idea what might be going on?
Thanks!
John
John Morley
Mark
PostPosted: Mon Sep 19, 2005 10:48 am     Reply with quote
Looks like to me that your index = 0 and enable interrupt statements are in the main loop so index is just about always 0. Also, you need some sort of signal that this is the start of a message. This could be a timeout or a special char recieved or even a break signal. You this to reset the index to 0.
John Morley
PostPosted: Mon Sep 19, 2005 6:51 pm     Reply with quote
Mark,
Yep, I can't believe I did that with Index=0 Rolling Eyes ....... I was moving some code around and never picked up on the error even after many checks! Also, I added a check for the start character (#) in the interrupt handler and all is well now!
Thanks!
John Morley
