		| Author | Message |
		| JimB
				| ACE KIT Excercise EX20.c which uses the keypad and the lcd. |
				|  Posted: Sun Sep 18, 2005 5:14 pm |   |
				| I have read all (well maybe not all) the comments regarding the lcd and keypad from other users, but no one seems to be using the ACE KIT.  I have gone through many of the excercises but this one has me stymied. The keypad connector is connected to Port D and the lcd is connected to the port D LCD header as instructed in the documentation.  The lcd lights but there is nothing displayed.
 Other posts have mentioned the need for pullup resistors but in this excercise the lcd is providing that requirement.
 If anyone has gone through this successfully please send me a tip or two.
 I have a little concern since the excercise document appears to not be in its final configuration.  Mine has several of the Figures blacked out, so I am wondering if it is going to have another pass through the editing process.
 Thanks,
 JimB
 The code follows;
 #include <16f877A.h>
 #fuses HS, NOWDT, NOPROTECT, NOLVP
 #include <lcd.c>
 #include <kbd.c>
 void main()   {
 char k;
 lcd_init();
 kbd_init();
 lcd_putc("\fReady....\n");
 while  (TRUE)    {
 k=kbd_getc();
 if(k!=0)
 if(k=='*')
 lcd_putc('\f');
 lcd_putc(k);
		| PCM programmer
				|  Posted: Sun Sep 18, 2005 6:02 pm |   |
				|  	  | Quote: |  	  | but no one seems to be using the ACE KIT. |
 CCS doesn't post the manuals or the schematics for any of this stuff,
 (unlike Microchip, who does post them) so it's tough for us to provide
 any support.
		| sseidman
				|  Posted: Mon Sep 19, 2005 7:27 am |   |
				| As I recall, the LCD port in the ACE kit works fine "out of the box".  There are two possible places where you can plug it it, port B, or port D.  If you use the keypad as well, you must use port B.  Make sure the driver file is talking to the correct port. |  |
		| JimB
				| Statement in the kbd.c |
				|  Posted: Mon Sep 19, 2005 7:47 pm |   |
				| After looking around here, the forum,  for similar problems, I read the kbd.c and found the statement about needing pullup resistors on the keypad unless the lcd is attached.  See next two lines taken directly from the kbd.c file.
 // Make sure the port used has pull-up resistors (or the LCD) on
 // the column pins
 So from this statement I am led to believe that having the keypad and the lcd on the same port was intentional.  I will try moving it to the B port and see what happens.
 I hope that CCS didn't make a mistake regarding this.  I know that they sometimes leave out little tidbits of information.
		| JimB
				|  Posted: Mon Sep 19, 2005 11:39 pm |   |
				| Moved the lcd to port B and removed comment lines to enable use of port B for the lcd.  Added the three pullup resistors to the column lines. Still no go.  Anybody have ideas.  I am basically parroting the excercise given.
		| PCM programmer
				|  Posted: Tue Sep 20, 2005 12:28 am |   |
				| That comment in the CCS example file is in error.     The pull-up resistors must be on the ROW pins for the kbd.c file.
		| JimB
				| Comments from CCS |
				|  Posted: Tue Sep 20, 2005 10:34 pm |   |
				| I asked CCS support about the problems I was having.  Here is the reply that was sent.
 "You need pull-ups (or LCD) on COL0, COL1, COL2 (D5-D7)."
 "To read the keypad the software will set ROW0 to low, and ROW1,ROW2 and ROW3 to high.
 If COL0-COL3 all read high then no key in ROW0 is pressed.  The software then sets ROW1
 low and the others HIGH.  Again if COL0-COL3 are all high nothing is pressed in that row.  If
 one of the COLx pins reads low then that column and the row that is now low will indicate
 the key that is pressed.  The software rotates through all rows and then repeats."
 AND
 "With this kit use port D for both the keypad and LCD.  The POT #10
 is used to adjust the LCD contrast.  From your description I think the
 contrast is not set right.  On power up you should see a row of black
 boxes, when lcd_init is called the screen should clear.  You should
 then see the text from the printf even before you press any keys."
 There was no mention of the pot in the exercise so I need to pursue that avenue now.  At least they gave an explanation of how the keypad is read.  Now I wish someone would go through the kbd.c and lcd.c and give a narrative explaining what is going on in these two files.  Being a beginner I find much of what is presented a little cryptic.  It is hard for me to separate the C functions from the other expressions much of the time.
		| PCM programmer
				|  Posted: Wed Sep 21, 2005 12:26 am |   |
				|  	  | Quote: |  	  | "You need pull-ups (or LCD) on COL0, COL1, COL2 (D5-D7)." "To read the keypad the software will set ROW0 to low, and ROW1,ROW2
 and ROW3 to high. If COL0-COL3 all read high then no key in ROW0 is
 pressed. The software then sets ROW1 low and the others HIGH. Again if
 COL0-COL3 are all high nothing is pressed in that row. If one of the COLx
 repeats."
 Maybe they're looking at a different driver file than me.  They have given
 a description that is the exact opposite of the way that KBD.C works,
 in terms of the Row and Column pins.   The KBD.C driver file in
 c:\Program Files\Picc\Drivers sets the column lines low, one at a time,
 and reads the rows.
 The following code is from the kbd_getc() routine.   I've added comments
 to show what the bitmasks are.
 If you look at the kdb_getc() code in KBD.C, you can see that the
 column variable "col" is incremented down at the bottom of the routine.
 Each time you call it, "col" will cycle through one of the values
 of 0, 1, and 2.    So, each time you call kbd_getc(), a different "case"
 in the switch statement is performed.   Notice what they do.
 The value "kbd" is equivalent to Port D.    They take the inverted
 form of the column bitmask, AND it with ALL_PINS, and shove
 it out to Port D.   They are setting one Column line low, in
 sequence, each time they call kbd_getc().
  	  | Code: |  	  | #define COL0 (1 << 5)   //  = 00100000b
 #define COL1 (1 << 6)   //  = 01000000b
 #define COL2 (1 << 7)   //  = 10000000b
 // The inverted forms of the column bitmasks are:
 // ~COL0 = 11011111b
 // ~COL1 = 10111111b
 // ~COL2 = 01111111b
 // ALL_PINS = 11111110b
 #byte kbd = 8
 switch (col) {
 case 0   : set_tris_kbd(ALL_PINS&~COL0);
 kbd=~COL0&ALL_PINS;
 case 1   : set_tris_kbd(ALL_PINS&~COL1);
 kbd=~COL1&ALL_PINS;
 case 2   : set_tris_kbd(ALL_PINS&~COL2);
 kbd=~COL2&ALL_PINS;
 Here is the row code from KBD.C.    Notice that they take
 the value of kbd (that is, they read Port D), and they mask
 it down with the bitmask of the Row that they want to test.
 Since once each pass, a Column line is held low, if a button
 is pushed, a connection will be made between that Column
 line and a Row line.   When they read the Row pins, and
 mask it down to a particular row, and if the result is zero,
 then they know the column and the row of the button that's
 been pushed.
 For this to work, the Row pins must have pull-ups on them.
 If they're floating, you can't be sure of the bit values
 that are read.
 Example:
 Suppose the button for COL2 and ROW3 is pressed.  Let's
 assume we're on the 3rd call to kbd_getc() from your main
 routine.  Then the line for Column 2 will be set low.
 First they read kbd (Port D), and mask it down with ALL_ROWS
 to see if any Row line is low.   If one is low, then they
 check to see which specific Row it is.  They do this with
 a series of if-else statements, below.
 When you use the value of "kbd" below, you have read
 the whole of Port D.   You've read both the Row pins
 and the Column pins.   But, the code is only testing
 the value of the Row pins, because it's using bitmasks
 for the Row pins.  This is why the Row pins, as inputs,
 must have pull-up resistors on them.   Otherwise they'd
 be floating and you could read any random value.  Without
 a pull-up, you might read a low value on a Row pin even
 though a button wasn't pushed on that row.
  	  | Code: |  	  | #define ROW0 (1 << 1)   // = 00000010b
 #define ROW1 (1 << 2)   // = 00000100b
 #define ROW2 (1 << 3)   // = 00001000b
 #define ROW3 (1 << 4)   // = 00010000b
 if((kbd & (ALL_ROWS))!=(ALL_ROWS)) {
 if((kbd & ROW0)==0)
 row=0;
 else if((kbd & ROW1)==0)
 row=1;
 else if((kbd & ROW2)==0)
 row=2;
 else if((kbd & ROW3)==0)
 row=3;
		| JimB
				|  Posted: Sat Sep 24, 2005 3:09 am |   |
				| I reviewed the great reply from PCM Programmer and learned a great deal from that reply.  However, I did get the keyboard and lcd to work as CCS advertised in their exercise, i.e. I got them to work correctly placing the lcd and the keypad on port D, without any pullups.  What is a little confusing is that without the program running I measured the voltages on the port D pins and found the following. D0 - low, D1 - +5V, D2 - +5V, D3 - low, D4 - low, D5 - +5V, D6 - low, and D7 - low.  The same hold when the program is loaded but no keypad buttons pushed.  This implies that two rows and one column is pulled up by the lcd??????
 Where is the book that explains all this stuff in detail.  Seems like this forum and all the code displayed is becoming my best instructor.
		| PCM programmer
				|  Posted: Sat Sep 24, 2005 11:41 am |   |
				| Download the specification for the controller chip used on many characters LCDs:
 http://www.melabs.com/downloads/hd44780u.pdf
 Go to page 54, which shows a schematic of the input circuits.
 Notice that signals DB0-DB7, R/W, and RS, are labeled with "pull up MOS".
 This means they are using a MOSFET to create a weak pullup on those pins.
 On page 48, they say the typical pull-up current is 50ua at 3v.
 This means the pullups are typically 60K ohms.
 While I was searching for the LCD driver document above, I also
 found a good appnote from Maxim on keypad interfacing.
 http://www.maxim-ic.com/appnotes.cfm/appnote_number/3414
 It can also be downloaded as a PDF, at the bottom of the page.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
