write_program_memory, software locks up when called
Goto page 1, 2  Next
Nick
PostPosted: Sun Sep 18, 2005 2:14 pm     Reply with quote
I'm trying to use loader.c as a boot loader, but after it trys and writes it stops responding
I'm pretty sure its locking up on the line
write_program_memory(addr, data, count);
count = 16
addr = 0
data should be correct because i dont get a checksum error
This chip is a pic16f876a. Please help
PostPosted: Sun Sep 18, 2005 2:15 pm     Reply with quote
What is your version of the PCM compiler ? This will be a number
like 2.734, 3.191, or 3.234, etc.
Nick
PostPosted: Sun Sep 18, 2005 2:17 pm     Reply with quote
3.187 registered under nick tullos
and forgot to mention that I disabled the interupts before the call.
Nick
PostPosted: Sun Sep 18, 2005 2:24 pm     Reply with quote
OK, I'll look at the code, but you don't have to give your name.
I don't work for CCS. I just like to do analysis on tech problems. Mr. Green
nick
PostPosted: Sun Sep 18, 2005 2:27 pm     Reply with quote
thank you very much.
I want to know if it its my problem or a CCS compiler problem. Thanks again
Nick
PostPosted: Sun Sep 18, 2005 2:59 pm     Reply with quote
I looked at the .LST files for a small test program for PCM vs. 3.187
and 3.233, and there are some differences.
But before I do any more, I have to say that I noticed that CCS puts
the code that writes to flash memory at address 0x0004.
So in your example, you're writing 16 bytes to address 0, which
will clobber the very code that's doing the writing.
Nick
PostPosted: Sun Sep 18, 2005 3:25 pm     Reply with quote
thanks for the tip, that is probably where the problem is happening.
Nick
PostPosted: Sun Sep 18, 2005 5:10 pm     Reply with quote
CCS PCM C Compiler, Version 3.187, 25251
               Filename: C:\Documents and Settings\nick\Desktop\SVN_New\BoostController\boost_alg_v3_7_boot.LST
               ROM used: 6836 (83%)
                         Largest free fragment is 511
               RAM used: 164 (45%) at main() level
                         243 (66%) worst case
               Stack:    6 worst case (5 in main + 1 for interrupts)
0000:  MOVLW  10
0001:  MOVWF  0A
0002:  GOTO   000
0003:  NOP
0004:  MOVWF  7F
0005:  SWAPF  03,W
0006:  CLRF   03
0007:  MOVWF  21
0008:  MOVF   0A,W
0009:  MOVWF  20
000A:  CLRF   0A
000B:  MOVF   04,W
000C:  MOVWF  22
000D:  MOVF   77,W
000E:  MOVWF  23
000F:  MOVF   78,W
0010:  MOVWF  24
0011:  MOVF   79,W
0012:  MOVWF  25
0013:  MOVF   7A,W
0014:  MOVWF  26
0015:  MOVF   7B,W
0016:  MOVWF  27
0017:  BCF    03.7
0018:  BCF    03.5
0019:  MOVLW  8C
001A:  MOVWF  04
001B:  BTFSS  00.1
001C:  GOTO   01F
001D:  BTFSC  0C.1
001E:  GOTO   032
001F:  MOVF   22,W
0020:  MOVWF  04
0021:  MOVF   23,W
0022:  MOVWF  77
0023:  MOVF   24,W
0024:  MOVWF  78
0025:  MOVF   25,W
0026:  MOVWF  79
0027:  MOVF   26,W
0028:  MOVWF  7A
0029:  MOVF   27,W
002A:  MOVWF  7B
002B:  MOVF   20,W
002C:  MOVWF  0A
002D:  SWAPF  21,W
002E:  MOVWF  03
002F:  SWAPF  7F,F
0030:  SWAPF  7F,W
0031:  RETFIE
0032:  BCF    0A.3
0033:  BCF    0A.4
0034:  GOTO   0FE
....................  //Current known problems
.................... // Defaults
.................... #DEFINE HVX 1
.................... #DEFINE HVY 0
.................... #DEFINE FVX 3
.................... #DEFINE FVY 3
.................... #DEFINE LOCKD 0
.................... #DEFINE HIGHB 175
.................... #DEFINE LOWB 160
.................... #DEFINE MAXB 183
.................... #DEFINE OVERPWM 85
.................... #DEFINE LOWSHIFTTIME 2
.................... #DEFINE HIGHSHIFTTIME 20
.................... #DEFINE SHIFTBUFFER 10
.................... #DEFINE SHIFTENABLE 1
.................... #DEFINE IDLEPWM 30
.................... #DEFINE LOWESTPWM 12
.................... #DEFINE UNDERBOOSTRCT 2
.................... #DEFINE OVERBOOSTRCT 1
.................... #DEFINE ENABLEUNDERBOOSTRCT 1
.................... #DEFINE ENABLEOVERBOOSTRCT 1
.................... //not used yet
.................... #DEFINE LOCKGAIN 0
.................... #DEFINE BOOSTGAIN 12
.................... #DEFINE ENABLEOVERBOOST 0
.................... #DEFINE ENABLEDYNAMICOVERBOOST 0
.................... #DEFINE GAINRESHIGH 2
.................... #DEFINE GAINRESLOW 0
.................... #DEFINE BOOSTADD 100
.................... #DEFINE BOOSTMULTI 80
.................... //PORT assigments for Version 1.0
.................... // B7 - Inside LED 2
.................... #DEFINE BOOSTLED PIN_B7
.................... // B6 - Inside LED 1
.................... #DEFINE ONLED PIN_B5
.................... // B5 - Outside LED 2
.................... // B4 - Outside LED 1
.................... // B3 - AUX FET
.................... // B2 - Main FET
.................... #DEFINE MAINFET PIN_B3
.................... // B1 - Switch
.................... #DEFINE BSWITCH PIN_B1
.................... // B0 - NA
.................... // C7 - RS232
.................... // C6 - RS232
.................... //set fuses
.................... //#fuses HS,NOWDT,NOPROTECT,NOLVP
.................... #include <16F876A.h>
....................  //////// Standard Header file for the PIC16F876A device ////////////////
.................... #device PIC16F876A
.................... #list
.................... #fuses HS,NOWDT,NOPROTECT,NOLVP
.................... #device *=16
.................... #use delay(clock=20000000)
01B8:  MOVLW  EB
01B9:  MOVWF  04
01BA:  BCF    03.7
01BB:  MOVF   00,W
01BC:  BTFSC  03.2
01BD:  GOTO   1CB
01BE:  MOVLW  06
01BF:  MOVWF  78
01C0:  CLRF   77
01C1:  DECFSZ 77,F
01C2:  GOTO   1C1
01C3:  DECFSZ 78,F
01C4:  GOTO   1C0
01C5:  MOVLW  7B
01C6:  MOVWF  77
01C7:  DECFSZ 77,F
01C8:  GOTO   1C7
01C9:  DECFSZ 00,F
01CA:  GOTO   1BE
01CB:  RETLW  00
.................... #use rs232(baud=38400, xmit=PIN_C6, rcv=PIN_C7)
.................... //#include <LOADER_enc2.c>
.................... #include <LOADER.c>
.................... ////                         loader.c                                  ////
.................... //// This driver will take an Intel 8-bit Hex file over RS232 channels ////
.................... //// and modify the flash program memory with the new code.  A proxy   ////
.................... //// function is required to sit between the real loading function     ////
.................... //// and the main code because the #org preprocessor command could     ////
.................... //// possibly change the order of functions within a defined block.    ////
.................... //// After each good line, the loader sends an ACKLOD character.  The  ////
.................... //// driver uses XON/XOFF flow control.  Also, any buffer on the PC    ////
.................... //// UART must be turned off, or to its lowest setting, otherwise it   ////
.................... //// will miss data.                                                   ////
.................... ////        (C) Copyright 1996,2003 Custom Computer Services           ////
.................... //// This source code may only be used by licensed users of the CCS C  ////
.................... //// compiler.  This source code may only be distributed to other      ////
.................... //// licensed users of the CCS C compiler.  No other use, reproduction ////
.................... //// or distribution is permitted without written permission.          ////
.................... //// Derivative programs created using this software in object code    ////
.................... //// form are not restricted in any way.                               ////
.................... #ifndef LOADER_END
.................... #define LOADER_END      getenv("PROGRAM_MEMORY")-1
.................... #if defined(__PCM__)
....................    #define LOADER_SIZE   0x65F
.................... //#elif defined(__PCH__)
.................... //   #define LOADER_SIZE   0x3FF
.................... //#endif
.................... #endif
.................... #define LOADER_ADDR LOADER_END-LOADER_SIZE
.................... #define BUFFER_LEN_LOD 64
.................... int  buffidx;
.................... char buffer[BUFFER_LEN_LOD];
.................... #define ACKLOD 0x06
.................... #define XON    0x11
.................... #define XOFF   0x13
.................... #SEPARATE
.................... unsigned int atoi_b16(char *s);
.................... #ORG LOADER_ADDR+10, LOADER_END auto=0 default
.................... void real_load_program (void)
....................    int1  do_ACKLOD, done=FALSE;
1B65:  BSF    03.5
1B66:  BCF    62.1
....................    int8  checksum, line_type;
....................    int16 l_addr,h_addr=0;
in my file it looks like flash code starts at 1B65, i could be reading the file wrong.
Nick[/code]
PostPosted: Sun Sep 18, 2005 5:12 pm     Reply with quote
0000:  MOVLW  10
0001:  MOVWF  0A
0002:  GOTO   000
0003:  NOP
0004:  MOVWF  7F
0005:  SWAPF  03,W
0006:  CLRF   03
0007:  MOVWF  21
0008:  MOVF   0A,W
0009:  MOVWF  20
000A:  CLRF   0A
000B:  MOVF   04,W
000C:  MOVWF  22
000D:  MOVF   77,W
000E:  MOVWF  23
000F:  MOVF   78,W
0010:  MOVWF  24
0011:  MOVF   79,W
0012:  MOVWF  25
0013:  MOVF   7A,W
0014:  MOVWF  26
0015:  MOVF   7B,W
0016:  MOVWF  27
0017:  BCF    03.7
0018:  BCF    03.5
0019:  MOVLW  8C
001A:  MOVWF  04
001B:  BTFSS  00.1
001C:  GOTO   01F
001D:  BTFSC  0C.1
001E:  GOTO   032
001F:  MOVF   22,W
0020:  MOVWF  04
0021:  MOVF   23,W
0022:  MOVWF  77
0023:  MOVF   24,W
0024:  MOVWF  78
0025:  MOVF   25,W
0026:  MOVWF  79
0027:  MOVF   26,W
0028:  MOVWF  7A
0029:  MOVF   27,W
002A:  MOVWF  7B
002B:  MOVF   20,W
002C:  MOVWF  0A
002D:  SWAPF  21,W
002E:  MOVWF  03
002F:  SWAPF  7F,F
0030:  SWAPF  7F,W
0031:  RETFIE
0032:  BCF    0A.3
0033:  BCF    0A.4
0034:  GOTO   0FE
01B8:  MOVLW  EB
01B9:  MOVWF  04
01BA:  BCF    03.7
01BB:  MOVF   00,W
01BC:  BTFSC  03.2
01BD:  GOTO   1CB
01BE:  MOVLW  06
01BF:  MOVWF  78
01C0:  CLRF   77
01C1:  DECFSZ 77,F
01C2:  GOTO   1C1
01C3:  DECFSZ 78,F
01C4:  GOTO   1C0
01C5:  MOVLW  7B
01C6:  MOVWF  77
01C7:  DECFSZ 77,F
01C8:  GOTO   1C7
01C9:  DECFSZ 00,F
01CA:  GOTO   1BE
01CB:  RETLW  00
1B65:  BSF    03.5
1B66:  BCF    62.1
Nick[/code]
Nick
PostPosted: Sun Sep 18, 2005 5:13 pm     Reply with quote
0000:  MOVLW  10
0001:  MOVWF  0A
0002:  GOTO   000
0003:  NOP
0004:  MOVWF  7F
0005:  SWAPF  03,W
0006:  CLRF   03
0007:  MOVWF  21
0008:  MOVF   0A,W
0009:  MOVWF  20
000A:  CLRF   0A
000B:  MOVF   04,W
000C:  MOVWF  22
000D:  MOVF   77,W
000E:  MOVWF  23
000F:  MOVF   78,W
0010:  MOVWF  24
0011:  MOVF   79,W
0012:  MOVWF  25
0013:  MOVF   7A,W
0014:  MOVWF  26
0015:  MOVF   7B,W
0016:  MOVWF  27
0017:  BCF    03.7
0018:  BCF    03.5
0019:  MOVLW  8C
001A:  MOVWF  04
001B:  BTFSS  00.1
001C:  GOTO   01F
001D:  BTFSC  0C.1
001E:  GOTO   032
001F:  MOVF   22,W
0020:  MOVWF  04
0021:  MOVF   23,W
0022:  MOVWF  77
0023:  MOVF   24,W
0024:  MOVWF  78
0025:  MOVF   25,W
0026:  MOVWF  79
0027:  MOVF   26,W
0028:  MOVWF  7A
0029:  MOVF   27,W
002A:  MOVWF  7B
002B:  MOVF   20,W
002C:  MOVWF  0A
002D:  SWAPF  21,W
002E:  MOVWF  03
002F:  SWAPF  7F,F
0030:  SWAPF  7F,W
0031:  RETFIE
0032:  BCF    0A.3
0033:  BCF    0A.4
0034:  GOTO   0FE
01B8:  MOVLW  EB
01B9:  MOVWF  04
01BA:  BCF    03.7
01BB:  MOVF   00,W
01BC:  BTFSC  03.2
01BD:  GOTO   1CB
01BE:  MOVLW  06
01BF:  MOVWF  78
01C0:  CLRF   77
01C1:  DECFSZ 77,F
01C2:  GOTO   1C1
01C3:  DECFSZ 78,F
01C4:  GOTO   1C0
01C5:  MOVLW  7B
01C6:  MOVWF  77
01C7:  DECFSZ 77,F
01C8:  GOTO   1C7
01C9:  DECFSZ 00,F
01CA:  GOTO   1BE
01CB:  RETLW  00
1B65:  BSF    03.5
1B66:  BCF    62.1
Nick[/code]
PostPosted: Sun Sep 18, 2005 6:00 pm     Reply with quote
First I should say that if you had registered and clicked the little box
that says "log me in automatically each visit", then you could have
deleted that extra post.
But anyway, your code shows the CCS interrupt dispatcher at address
0x0004 and it's checking for the Timer2 interrupt.
Do you have global interupts enabled while you're flashing the program
memory ? If so, a Timer2 interrupt could occur. What happens
when it tries to execute code in the interrupt dispatcher that's been
partially erased or re-programmed ? It probably crashes.
So I think you should disable Global interrupts before you call the
write_program_memory() function.
Nick
PostPosted: Sun Sep 18, 2005 6:12 pm     Reply with quote
////                         loader.c                                  ////
#ifndef LOADER_END
//#endif
int  buffidx;
#define ACKLOD 0x06
#define XON    0x11
#define XOFF   0x13
#SEPARATE
   int32 addr;
   #if getenv("FLASH_ERASE_SIZE")>2
      int32 next_addr;
   int8  dataidx, i, count;
   int8  data[32];
//printf("test\r\n");
   while (!done)  // Loop until the entire program is downloaded
      buffidx = 0;  // Read into the buffer until 0x0D ('\r') is received or the buffer is full
      do {
         buffer[buffidx] = getc();
      } while ( (buffer[buffidx++] != 0x0D) && (buffidx <= BUFFER_LEN_LOD) );
      putchar (XOFF);  // Suspend sender
      do_ACKLOD = TRUE;
      // Only process data blocks that start with ':'
      if (buffer[0] == ':') {
//         printf(":\n\r");
         count = atoi_b16 (&buffer[1]);  // Get the number of bytes from the buffer
//         printf("atoi_b16\n\r");
         // Get the lower 16 bits of address
         l_addr = make16(atoi_b16(&buffer[3]),atoi_b16(&buffer[5]));
//         printf("l_addr\n\r");
         line_type = atoi_b16 (&buffer[7]);
         printf("type =%u\n\r",line_type);
         addr = make32(h_addr,l_addr);
         #if defined(__PCM__)  // PIC16 uses word addresses
            addr /= 2;
         // If the line type is 1, then data is done being sent
         if (line_type == 1) {
            done = TRUE;
         } else if ((addr < LOADER_ADDR || addr > LOADER_END) && addr < 0x2000){
         } else if ((addr < LOADER_ADDR || addr > LOADER_END) && addr < 0x300000){
            checksum = 0;  // Sum the bytes to find the check sum value
            for (i=1; i<(buffidx-3); i+=2)
               checksum += atoi_b16 (&buffer[i]);
            checksum = 0xFF - checksum + 1;
            if (checksum != atoi_b16 (&buffer[buffidx-3]))
               do_ACKLOD = FALSE;
            else   {
               if (line_type == 0) {
              printf("storing data\n\r");
              disable_interrupts(GLOBAL);
                  // Loops through all of the data and stores it in data
                  // The last 2 bytes are the check sum, hence buffidx-3
                  for (i = 9,dataidx=0; i < buffidx-3; i += 2)
                     data[dataidx++]=atoi_b16(&buffer[i]);
                        if ((addr!=next_addr)&&(addr&(getenv("FLASH_ERASE_SIZE")-1)!=0))
                     #else
                        if ((addr!=next_addr)&&(addr&(getenv("FLASH_ERASE_SIZE")/2-1)!=0))
                           erase_program_eeprom(addr);
                     next_addr = addr + 1;
//               printf("before write\n\r");
               printf("addr = %ld , count = %u \n\r",addr,count);
//                  enable_interrupts(GLOBAL);
               printf("X\n\r");
               else if (line_type == 4)
                  h_addr = make16(atoi_b16(&buffer[9]), atoi_b16(&buffer[11]));
      if (do_ACKLOD)
      putchar (ACKLOD);
      putchar(XON);
   printf("Rebooting\n\r");
   putchar (ACKLOD);
   putchar(XON);
   //#ifndef _bootloader
   reset_cpu();
   //#endif
unsigned int atoi_b16(char *s) {  // Convert two hex characters to a int8
   unsigned int result = 0;
   int i;
   for (i=0; i<2; i++,s++)  {
      if (*s >= 'A')
         result = 16*result + (*s) - 'A' + 10;
         result = 16*result + (*s) - '0';
   return(result);
#ORG default
#ORG LOADER_ADDR, LOADER_ADDR+9
void load_program(void)
      real_load_program();
i disable the interupts before the memory write, I never make it to the printf ("x"); code.
Nick[/code]
PostPosted: Sun Sep 18, 2005 6:52 pm     Reply with quote
On Monday, I'll test PCM vs. 3.187 with a 16F877A chip and see if
write_program_memory() works.
Nick
PostPosted: Mon Sep 19, 2005 9:23 am     Reply with quote
thanks
PostPosted: Mon Sep 19, 2005 1:28 pm     Reply with quote
I ran the test program below, and it failed with PCM vs. 3.187.
It only displays:
Start
It worked with PCM vs. 3.234. With that version, it displayed:
Start
Done
#include <16F877A.H>
#fuses  XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock = 4000000)
int8 count = 0;
#int_timer2
void rtcc_isr(void)
count++;
main(void)
int8 count;
int16 addr;
int8 data[16] = {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};
int8 value;
setup_timer_2(T2_DIV_BY_1, 127, 1);
printf("Start\n\r");
count = 16;
addr = 0;
printf("Done\n\r");
Goto page 1, 2  Next
Page 1 of 2
