18F4431 won't let in code
aaaaamartin
PostPosted: Sat Sep 17, 2005 10:22 am     Reply with quote
I recently ordered 5 x 18F4431 PDIP, and 3 x QFN.
The first Chip I tried works flawlessly, however the other CHIPS
don't take a single instruction into flash.
I can read what is in the Flash, but not write.
I use a Tait like burner and freeware soft, as described here.
http://www.sprut.de/electronic/pic/brenner/index.htm#brenner5
http://www.sprut.de/electronic/soft/p18/p18.htm
Of course this behaviour can be software and / or burner based,
but why does it work with one of the Chips ?
I'm confused !
Thanks for suggestions.
Martin
PostPosted: Sat Sep 17, 2005 10:32 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=20466
aaaaamartin
PostPosted: Sat Sep 17, 2005 11:06 am     Reply with quote
HI,
I've connected all four supply pins.
Makes no difference with the working device, if you only connect two.
Martin
PostPosted: Sat Sep 17, 2005 12:00 pm     Reply with quote
The programmer software for the 18F4431 is experimental. It may
not work properly. The web page says:
The experimental version V 1,5 alpha 3
asmallri
PostPosted: Sat Sep 17, 2005 6:22 pm     Reply with quote
Have you disabled LVP or pulled up the LVP pin?
Regards, Andrew
aaaaamartin
PostPosted: Tue Sep 20, 2005 3:43 pm     Reply with quote
just finished my ICD2-clone.
See www.stolz.de.be for details.
Everything workin ' now !
Thx
Martin
