2465, 24128, 24256 why driver diff?
Joshua Lai
PostPosted: Sat Sep 17, 2005 3:27 am     Reply with quote
Why the eeprom drivers 2465.c, 24128.c, and 24256.c are different?
I tried to modify the 2465.c and 24128.c to use on my 24LC256 EEPROM, it can work with small memory address, but I cannot write/read the larger memory bank.
A few things i don't understand:
what means?
#define hi(x) (*(&x+1))
in 24128.c, this is for what?
for (i=0;i<3;i++) {
i2c_start();
i2c_write(0xa0);
i2c_write(0xff);
i2c_write(0xff);
if(i==2)
i2c_write(0x2);
i2c_write(0x2+i);
i2c_stop();
why use this to send control byte to eeprom?
i2c_write(((0xa0)|(hi(address)>>5))&0xfe);
Another question is, I found that using these drivers to write and read continuous data is not very efficient. How to modify the driver to do page write and sequential read? How to issue ACK?
PostPosted: Sun Sep 18, 2005 2:09 pm     Reply with quote
You have a very old version of the compiler, that doesn't have that driver.
So just do a web search. There are many students who use the CCS
compiler, and quite often they post their code or the drivers.
So, use http://www/google.com and find it. Search for the name
of one of the functions that you know will be in the driver, and search
for CCS, and the name of the EEPROM. Try this search string:
init_ext_eeprom CCS 24LC256
Here it is:
http://www.d.hoen.ca:8080/programming/programming/AUVic2004/Development/PICC/Drivers/24256.C
Joshua Lai
PostPosted: Sun Sep 18, 2005 9:05 pm     Reply with quote
Oh, dear sir,
How to do page write or sequential read using this driver?
What this for?
status=i2c_write(0xa0);
while(status==1)
i2c_start();
PostPosted: Sun Sep 18, 2005 9:48 pm     Reply with quote
This link has some code which can write to a page:
http://www.ccsinfo.com/forum/viewtopic.php?t=17787
There is other page mode code on the forum, but it's more complicated
than the code in the link above.
What this for?
while(status==1)
i2c_start();
Download the 24LC256 data sheet and read Section 7.0:
http://ww1.microchip.com/downloads/en/DeviceDoc/21203N.pdf
Joshua Lai
Fast eeprom reading
PostPosted: Tue Sep 20, 2005 7:37 pm     Reply with quote
I tried writing my own program to write and read eeprom, it is working !!
#include <16F876.h>
#use i2c(master,sda=PIN_C4,scl=PIN_C3)
#fuses hs,noprotect,nowdt,nolvp
#byte PORTB=6
int a, r;
main()
output_float(PIN_C3); //initialize eeprom
output_float(PIN_C4);
r=0;
set_tris_b(0);
portb=0x01; delay_ms(1000);
portb=0x00; delay_ms(1000);
i2c_start();
i2c_write(0xA0); //control write
i2c_write(0x00); //address (max 7FF8)
i2c_write(0x00);
i2c_write(0x01); //data (max page 64)
i2c_write(0x02);
i2c_write(0x04);
i2c_write(0x10);
i2c_write(0x20);
i2c_write(0x40);
i2c_write(0x80);
i2c_stop();
i2c_start();
i2c_write(0xA0);
i2c_write(0x00);
i2c_write(0x00);
i2c_start();
i2c_write(0xA1); //control read
for(a=0;a<8;a++)
{ r = i2c_read();
portb=r; delay_ms(1000);
What I actually need to do is abitrary waveform generation. I need to store and read large amount of data in the eeprom, where time accuracy (sampling rate) is very important, fast is important also. So I have to count how much time PIC spent to read the eeprom.
Instead of using the built in driver 24256, I write my own program to read the eeprom. I found that I save at least hundred lines of assembly code.
But I don't really understand the assembly code, does i2c_read() same as sequential read in the eeprom datasheet?
I can also read out the eeprom data using hyperterminal (through PIC). But how can I use hyperterminal to write the eeprom? Because my icprog 1.04 showing error when verifying the eeprom. Type in the data on hyperterminal one by one is too slow.
