Pre Processor Directive: __FILE__
Freddie
PostPosted: Fri Sep 16, 2005 1:47 pm     Reply with quote
I'm using the __FILE__ pre processor directive in my code to display to the user the file name of the code they are running, soy they know which version of the software is running (code below). The issue is that my file name path is apparently too long and the complier (v3.233) complains that the name is too long. If I move the file to my c:\ directory it works fine (because that path is much shorter).
Does anyone have a work around or slick way to extract just the file name from the full path? I need to leave the souce files in the dirctories they are in, for sanity's sake. Thanks.
fprintf(serialPC, "%S\r\n", __FILE__);
Humberto
PostPosted: Fri Sep 16, 2005 2:28 pm     Reply with quote
After the string comma fprintf is expecting a value, __FILE__ is an identifier.
Try this way:
fprintf(serialPC, __FILE__);
Humberto
Freddie
PostPosted: Fri Sep 16, 2005 2:37 pm     Reply with quote
Humberto,
Thanks. It's not that I can't get __FILE__ to work. It's that the file path/name is too long and causes an error, if I do it the way I showed, or the way you suggested.
*** Error 6 "C:\Documents and Settings\blah\My Documents\PIC Code\CODE\blahblahblah\blahblahblah\blahblahblahblahblah.c" Line 108(19,20): String too long   fprintf
I guess the questions is: Is there a way to extract just the file name from __FILE__ and not the entire path I need to do this as a directive, not programitically, which would use up too much RAM.
Humberto
PostPosted: Fri Sep 16, 2005 2:52 pm     Reply with quote
I know what you mean, __FILE__ take the full path.
Work around this? move your source file to/close to the main root unless another better idea. Confused
Humberto
PostPosted: Fri Sep 16, 2005 3:09 pm     Reply with quote
It'll cost you quite a lot of ROM (since the whole filename will be held in ROM once you use it), but you could probably do it with something like:
int8 len;
int8 ctr;
clrcount() {
   len=0;
   ctr=0;
count(int8 chr) {
   ++len;
   if (chr=='\\') ctr=len;
output(int8 chr) {
   if (ctr) --ctr;
   else putc(chr);
//Then when you want the final filename, use:
   clrcount();
   count(__FILE__);
   len=ctr;
   output(__FILE__);
This takes advantage of the CCS shortcut, where a function that handles an int8, if called with a constant string will be repeatedly called with the successive characters in the string. Clrcount, sets two global counters to zero. Then 'count', counts along the string, and whenever a file name seperator is found, moves the second counter to point to this. Hence it should return with the position of the last filename seperator. I then call the output routine. This does exactly the same 'walk', but only starts outputing characters to the putc, once the address of the last seperator is passed.
It should give just the filename!.
PostPosted: Fri Sep 16, 2005 3:21 pm     Reply with quote
While you were doing yours, I was doing one too.
Might as well post it. Pretty much the same idea.
This program just proves that I can find the backslash
character right before the filename. If I can find that,
then I have the filename.
#include <16F877.H>
#fuses  XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock = 4000000)
const int8 pathname[] = __FILE__;
main(void)
int8 index;
index = 0;
while(pathname[index++]);
index -=2;
while(pathname[index--] != '\\');
index++;
printf("index = %d\n\r", index);
printf("index char = %c\n\r", pathname[index]);
PostPosted: Fri Sep 16, 2005 4:08 pm     Reply with quote
I think your idea of declaring the pathname, is probably far better (I suspect mine will store it twice). However I think finding the seperator 'on the way' as I do it, is neater.
I suspect a combination of the two routines would probably be the 'best' way of doing it.
Some sentence involving 'minds' and 'alike' applies here. :-)
Freddie
PostPosted: Mon Sep 19, 2005 8:28 am     Reply with quote
Thanks guys this is really helpful.
I wish there that __FILE__ was more like this:
__FILE_NAME_WITH_OUT_PATH__
Laughing Cool Shocked Shocked
Mark
PostPosted: Mon Sep 19, 2005 8:40 am     Reply with quote
Just declare a const string with you firmware version and use that
PostPosted: Mon Sep 19, 2005 9:03 am     Reply with quote
I've done this in the past, but I forget to update the const string with the new firmware version, then I have several different versions floating around with the same firmware version number. Gets confusing.
Mark
PostPosted: Mon Sep 19, 2005 9:06 am     Reply with quote
Then create yourself a checklist of things that you need to do in order to release your firmware. Do you even do a test on it? Part of the test could include the firmware revision.
Freddie
PostPosted: Mon Sep 19, 2005 1:25 pm     Reply with quote
Mark, You must be in "management" or from the "Quality Assurance" department. Wink Very Happy
Mark
PostPosted: Mon Sep 19, 2005 2:05 pm     Reply with quote
Nope, I just don't like for the field guys to come back and tell me that they found a bug Laughing Code reviews and software verification tests help reduce those "added features".
