		| Author | Message |
		| Bart
				| How to ftoa ? |
				|  Posted: Thu Sep 15, 2005 4:23 pm |   |
				| Hello,
 I need to convert a float back to an char array.
 I tryed this
  	  | Code: |  	  | fprintf(MODEM,"SPEED field in buffer : %S knots ",temp_buffer);
 temp_buffer = (atof(temp_buffer) * 1.852) + '0';
 temp_buffer[8] = 0;
 fprintf(MODEM,"( %3.3f km/uur)\n\r",temp_buffer);
 but this won't compile.
 The
 is giving something in the form 	  | Code: |  	  | atof(temp_buffer) * 1.852 |
 x.xxxxxxxx
 xx.xxxxxxx
 xxx.xxxxxx
 (no more than 3 before the dot, don't need more than 3 after the dot)
 Can someone correct my code ?
 Thanks for the great help.
 PS : Can't use other/additional variables due to RAM limitations.
 I like Skype (www.skype.com), my username is BplotM
		| PCM programmer
				|  Posted: Thu Sep 15, 2005 5:50 pm |   |
				|  	  | Quote: |  	  | I need to convert a float back to an char array. |
 The output of the following test program is:  1.23
  	  | Code: |  	  | #include <16F877.H> #fuses  XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
 #use delay(clock = 4000000)
 main(void)
 float f;
 char buffer[20];
 f = 1.234;
 sprintf(buffer, "%4.2f", f);
 printf("%s", buffer);
 | You cannot post new topics in this forum You cannot reply to topics in this forum
