Output pin interferes with other pin???????
kgn340
PostPosted: Thu Sep 15, 2005 4:45 pm     Reply with quote
here it goes ...
PIC16F88 running from internal 8MHz
PCM v3.215
codes snippet:
output_high(PIN_A1);
output_low(PIN_A0);
symptom:
pin A1 does indeed go HIGH, but after the output_low takes BOTH A0 and A1 low
also, if i try this:
output_high(PIN_A0);
pin A0 will go HIGH but A1 stays low !!!!
what the heck????
any ideas???
(i've isloated the pins and have tried different 16f88 chips).
PostPosted: Thu Sep 15, 2005 5:42 pm     Reply with quote
Look at these two threads, and then post a full test program, which
shows all your i/o port setup code, and your fuses, etc.
ie., how are you setting up the analog port ?
http://www.ccsinfo.com/forum/viewtopic.php?t=22778&highlight=readmodifywrite
http://www.ccsinfo.com/forum/viewtopic.php?t=23756&highlight=readmodifywrite
croc4
Check your setup_xxxx options
PostPosted: Thu Sep 15, 2005 10:51 pm     Reply with quote
I had the same problem until I turned off the analog ports
// Turn off the ADC
setup_adc_ports(NO_ANALOGS);
try this and see if things get better
kgn340
Re: Check your setup_xxxx options
PostPosted: Fri Sep 16, 2005 9:13 am     Reply with quote
WOW. This did it! THANKS!!!!
i guess my 'setup_adc(ADC_OFF)' just wasn't cutting it.
Thanks again!
-kev
PostPosted: Fri Sep 16, 2005 9:59 am     Reply with quote
Yes.
There is a critical difference in these two commands. setup_adc(ADC_OFF), just turns off the ADC, but still leaves the input multiplexer all setup to route the signals to the sampler. Use this, to save power, while the input capacitors are charging, or when the chip is to sleep. Setup_adc_ports, actually configures the inputs.
adrian
PostPosted: Mon Sep 19, 2005 6:04 am     Reply with quote
Ah! this might answer the problem I am having with the 16F913. I was trying to use setup_adc(ADC_OFF) to turn off the ADC, followed by setup_comparator(nc_nc) to turn off the comparator. This had the effect of turning AN5 into an input from the digital output originally declared.
Thanks for the posting.
