wintermute
Design question |
Posted: Wed Sep 14, 2005 5:03 pm |
I'm using a modified circuit for a capacitive switch for my pic. I've created the switch in firmware the usual way
(i.e.
port_b_pullups(TRUE);
if(!input(BUTTON) {
//do something
on a port B pin. Basically, connect pin to ground to operate the switch. This particular circuit will constantly send +5-volts to the pin until a finger touches metal contacts which will bring the b-port pin to ground potential.
My question is: will constantly sending 5 volts to the pin except for button presses damage the circuit; and will the firmware still detect a button press?
Thanks for reading,
--wintermute |
SherpaDoug
Posted: Wed Sep 14, 2005 7:03 pm |
We need to know a lot more about this "capacitive switch" to help you? Is this a commercially built module? _________________ The search for better is endless. Instead simply find very good and get the job done. |
wintermute
schematic |
Posted: Wed Sep 14, 2005 7:45 pm |
It's a pretty simple circuit, here is a schematic: (sorry for the blurriness)
![](http://www.geocities.com/heathtech123/finger1.jpg) |
SherpaDoug
Posted: Thu Sep 15, 2005 7:38 am |
To answer your original question, No running 5V to the PIC pin all the time is no problem as long as that is the same 5V supply that runs the PIC. Putting 5V on a pin while the PIC is not powered can cause problems. You should be able to remove the 1 meg resistor and just let the port B pullups do the job safely.
I do see two other problems with your circuit:
1) If someone on a dry day shuffels across a carpet and reaches out with their finger charged with static electricity to 10,000V and touches the sense electrode first, your FET is going to be destroyed in an instant. You should put a Zener diode from the gate to ground to clamp the positive voltage to a safe value. The Zener will foreward conduct to clamp negative voltages.
2) If someone toughes the +5V electrode with something grounded they could crash the 5V supply. I would split the 47K resistor into two 22K resistors and put one on each button. On the other hand now you may have a problem if the finger is too well grounded (the person may be dripping wet) and the finger grounds the sense button instead of pulling it high. Depending on the application maybe a 5K resistor in the +5V electrode is better. You may have to experiment.
As a safety note it is good to limit worst case current through the human body to 1mA or less.
Also there is nothing capacitive about this switch. I would not refer to it by that name. _________________ The search for better is endless. Instead simply find very good and get the job done. |
wintermute
Well answered. |
Posted: Thu Sep 15, 2005 11:40 am |
Extremely informative, thank you very much for your help, SherpaDoug. My apologies for using the wrong term, would just, touch-switch be more accurate?
I don't want to get to far off-topic of CCS or pics, but while I have the attention of a knowledgeable person... I've heard that for what I think is called a single-contact, capacitive switch, you must have earth ground. Is that accurate?
Thanks again,
--wintermute |
Mark
Posted: Thu Sep 15, 2005 12:10 pm |
You might also look at an MC33794 from Freescale. It is an Electric Field Sensing IC that would work nicely for you. |
yerpa
Posted: Thu Sep 15, 2005 2:31 pm |
You can make a touch switch based on capacitive principles using the PIC as follows: Generate a square wave with the PIC (i used a 555 timer - more current to do many switches) - send this square wave thru diode and resistor divider to touch bolts (single-ended, like an antenna). Then, readback the touch bolts and count how long the falling edge is delayed compared to the falling edge directly from the square wave generator. When a finger adds capacitance to the circuit (parasitic), it takes longer for the falling edge of the waveform to reach logic 0. Works very nice as long as the wires to the touch bolts are less than about 24 inches. I could send a schematic if you are interested. I built a bunch of these boards for a customer in 1994, haven't used them since then. Each board had five PICs and read 40 touch bolts. |
newguy
SherpaDoug
Posted: Thu Sep 15, 2005 2:48 pm |
For a one contact capacitive sensor you would need at least a capacitive connection to ground, but that is not hard to get. Think of the electric lamps that turn on by touching them. On the other hand they aren't too reliable at working on the first touch. A lot depends on your application.
One approach would be to build a RC oscillator from a couple of inverters that used a small cap, say 100pF. Connect the "hot" side of the oscillator cap through a bigger cap , say 0.01uF, to the sense electrode. Then have the PIC monitor the frequency of the oscillator. The frequency should drop noticably when you touch the sense electrode.
You could model the oscillator from the description of the RC oscillator mode on the PIC datasheet, though such things are also used zillions of other places. Make sure to take care of static electricity protection as I mentioned earlier. _________________ The search for better is endless. Instead simply find very good and get the job done. |
