CCS-MPLAB Plugin
Barney
CCS-MPLAB Plugin
PostPosted: Mon Sep 12, 2005 3:33 pm     Reply with quote
I have been using MPLAB 7.21 & PCM 3.212 with no problems. I just installed PCH 3.233 into another directory (PCM & PCH are different versions) and MPLAB doesn't see the CCS tool suite anymore.
Do I just need to re-install the plug-in?
Is the plug-in version sensitive to either MPLAB or the CCS compiler?
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Mon Sep 12, 2005 3:40 pm     Reply with quote
Yes, you have to re-install the plug-in. It will prompt you for the new directory.
Everytime a new version of CCS gets released, then i re-install the plug-in into that specific directory each time.
Barney
PostPosted: Mon Sep 12, 2005 4:06 pm     Reply with quote
OK, got past that hurdle, then Grrrrrrr.
I complied a short program and got:
    Clean: Deleting intermediary and output files.
    Clean: Deleted file "C:\Documents and Settings\mcabeflusc\My Documents\18FSerial\18FSerial.mcs".
    Clean: Done.
    Executing: "C:\Program Files\PCH\PICC\Ccsc.exe" "18FSerial.c" +FH +DF +LN +T -A +M +Z +Y=9 +EA
    Error: The selected compiler: "PCH" is not installed on this PC
    Halting build on first failure as requested.
    BUILD FAILED: Mon Sep 12 14:52:01 2005
I had just installed PCH into a separate directory (Programs\PCH\PICC) which maybe confusing it.
Suggestions?
MikeValencia
PostPosted: Mon Sep 12, 2005 5:22 pm     Reply with quote
I've had the same problem "PCH not installed..."
It's because you forgot to put the "pch.crg" file in the directory before you installed PCH.
So here are the steps i usually follow:
Suppose the version is PCH 3.230
1. Create a folder C:\Program Files\PICC_3_230\
2. Create a subfolder C:\Program Files\PICC_3_231\PICC\
3. Copy your registration file "pch.crg" to both directories above. (I'm not sure which directory the installation uses, so i copy pch.crg into both).
4. Install PCH into the directory of '2' above.
5. Install the Plug-In into the directory of Step '2' above.
Barney
PostPosted: Mon Sep 12, 2005 6:47 pm     Reply with quote
Still no joy. I didn't see why the pch.crg file had to be present BEFORE installing, so I just copied if from the PICC directory up to the PCH directory. Same problem.
Then I tried a fresh install following your procedure step by step. I copied pch.crg from the CDROM to both directories before installing PCH. Same failure:
    Clean: Deleted file "18FSerial.ERR".
    Clean Warning: File "C:\Documents and Settings\mcabeflusc\My Documents\18FSerial\18FSerial.o" doesn't exist.
    Clean: Done.
    BUILD FAILED: Mon Sep 12 17:43:20 2005
Rebooted the PC and tried compiling again, same failure.
Suggestions?
MikeValencia
PostPosted: Mon Sep 12, 2005 7:30 pm     Reply with quote
Oh i think I see why.
You are attempting to execute ccsc.exe from C:\Program Files\PICC\
but the proper ccsc.exe file resides in C:\Program Files\PICC_3_230\PICC\
To correct this, go to MPLAB,and use the pulldown menu to correct your 'language toolsuite':
Project --> Select Language Toolsuite
Use the 'browse' button to correct the directory from where you're pulling off ccsc.exe
I think that should take care of it.
Mark
PostPosted: Mon Sep 12, 2005 8:38 pm     Reply with quote
    Clean: Done.
Suggestions?
It should be in the PICC dir.
Mark
"Executing: "C:\Program Files\PCH\PICC\Ccsc.exe" "18FSerial.c" +FH +DF +LN +T -A +M +Z +Y=9 +EA
That's where he said that he installed it.
Barney
PostPosted: Tue Sep 13, 2005 9:51 am     Reply with quote
Well, I had to get something going. I renamed my original \PICC folder (with PCM compiler) to \PCM and installed PCH into a new \PICC directory. Then I installed the plug-in and reset the project tool location in my 18F project to \PICC. It works.
I am guessing I will have to have a PCM and a PCH directory and rename the one I want to use to PICC then reinstall the plug in and probably reset the tool path each time I switch from 16F to 18F parts.
Having PCM & PCH co-existing on the same PC with MPLAB seems like a pretty typical setup. Why does CCS make it so damn hard?
Mark
PostPosted: Tue Sep 13, 2005 11:25 am     Reply with quote
Here are a couple of options:
1. Upgrade PCM to the same version and install into the same directory.
2. Search the forum for a post I did a few months back telling how to do this by creating a legacy third party tool suite. It requires a few bits of registry hacking but it works for me. I use it to compile with different versions of PCM compiler.
Barney
PostPosted: Tue Sep 13, 2005 9:39 pm     Reply with quote
Appreciate the suggestions. I researched this issue before buying PCH and found your post with the registry changes. Frankly it is a little more than I want to bite off. For now I will be doing 90% PCM and 10% PCH, so hopefully I won't need to switch back and forth too often.
