source code for timing diagram
Atma
PostPosted: Wed Sep 07, 2005 4:44 am     Reply with quote
hi there
I am trying to write a program for the timing diagram figure 6.1 in manual 39025f.pdf related to the PIC16F873 in C but have no idea how to go about doing that. Can some one tell me how to write the source code? thanks
All help will be appreciated.
PostPosted: Thu Sep 08, 2005 1:20 pm     Reply with quote
I am trying to write a program for the timing diagram figure 6.1 in manual 39025f.pdf related to the PIC16F873 in C but have no idea how to go about doing that. Can some one tell me how to write the source code ?
You can use software SPI to make the signals.
http://www.ccsinfo.com/forum/viewtopic.php?t=23791&highlight=software+spi
Also read how other people make PIC programmers:
http://www.piclist.com/techref/microchip/devprogs.htm
newguy
PostPosted: Thu Sep 08, 2005 1:37 pm     Reply with quote
Take a careful look at the timing diagram, then write code to do what's in it.
For example, both the data & clock lines must be low before MCLR is set high. They must also be low for at least 100 ns before MCLR is raised (tset0 from Table 6-1).
This would be coded something like:
output_low(CLOCK_PIN);
output_low(DATA_PIN);
delay_us(1); // only have to delay for 100 ns, but this will make sure the delay is enough
output_high(MCLR_PIN);
You'll have to define CLOCK_PIN etc to correspond to individual pins on the programming PIC.
From the diagram, once the above instructions have executed, everything then must "hold" for thold0. From Table 6-1, thold0 is at least 5 us.
Now you'd add the following line to account for this delay:
delay_us(7); // 7 is "at least" 5, plus some padding, just in case
And so on, and so on, and so on.
Atma
PostPosted: Mon Sep 12, 2005 8:16 am     Reply with quote
hi there
thanks for the answer.
I have done that. Where i am confused is where i have to send a 14 bit data word when the clock cycle completes 16 cycles. How do i go about doing that ?
thanks
newguy
PostPosted: Mon Sep 12, 2005 11:04 am     Reply with quote
Someone else will have to help you here. The two extra bits are a start bit tacked onto the beginning and a stop bit tacked onto the end. The documentation does describe them. What's not clear, from my (quick) perusal of the documentation and the timing diagram, is what the start & stop bits should be - high or low.
The timing diagram seems to indicate that the start & stop bits may be high or low. Perhaps it doesn't matter? Try it with them high, low, or some combination to see if it works or not.
PostPosted: Mon Sep 12, 2005 11:07 am     Reply with quote
but then how do i code it in c? thats where i am confused. whats the code i would use in c to append the start and stop bis and the rest of the data word?
thanks
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Mon Sep 12, 2005 11:44 am     Reply with quote
thanks
You'll need a combination of delay_us() calls, output_high(), output_low(), etc.
Do you know how to program in C Question
