Getting started with PIC's...what would you do differently?
jseidmann
PostPosted: Mon Sep 12, 2005 7:09 am     Reply with quote
Hi everyone,
I'm currently getting started with PIC programming. I have done some work with them in the past, but I have never started the work from scratch. I need something to get me started and up and running relatively quickly. I'd like a good development board or something with a PIC already on it so I just have to connect it to the ICD and the C compiler and load an example program onto it and it'll work pretty quickly. I"m willing to spend $300 or so on the development board & ICD. What would all of you recommend to help me get started quickly and get PIC'ing?
Seidleroni
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Mon Sep 12, 2005 7:33 am     Reply with quote
You can buy a PICDEM-2 Plus (don't forget the "Plus"), which a lot of people here use, as well as myself, to get proof-of-concept ideas running. It has a MAX232 chip to readily hook up to a PC's serial port, which you can run Hyperterminal on for debugging, a bank of LEDs, serial eeprom and temperature sensor to demonstrate I2C, an LCD, pushbuttons, and it supports a 28-pin, 18-pin, or 40-pin PIC. It's only $99, and In my opinion, is the most efficient general PIC programming demo board you'll need. (If you want to do speciallized things like CAN, USB,or Ethernet, then you'll need the more specialized demo boards that Microchip offers.)
jseidmann
PostPosted: Mon Sep 12, 2005 8:09 am     Reply with quote
If I purchase the PicDem 2 plus board, can I use it with the CCS made ICD-U and CCS's C compiler?
bfmitch
PostPosted: Mon Sep 12, 2005 8:57 am     Reply with quote
On my first project I decided to use pins for serial comms other than the built in UART. I seem to remember that I had what seemed like a good reason for it at the time. Later on, after products were in the field, I really wished I had used the built in UART.
I use a rather heavily modified Lab-X2 board from MicroEngineering Labs. I have an interface board for working with the ICD-U where the PIC is mounted. It uses a wire wrap socket for the PIC to plug into the experimenter board. I can use it like a debugger pod, with some limitations, on product boards.
Can you say Low Budget?
MikeValencia
PostPosted: Mon Sep 12, 2005 9:20 am     Reply with quote
Of course, it has an RJ-11 jack on it for convenient debugging and programming by either an ICD-U (CCS) or ICD-2 (Microchip).
There are also some demo programs that have been contributed for it. For example:
TC74 Temperature Sensor:
http://www.ccsinfo.com/forum/viewtopic.php?t=24083&highlight=picdem2
LCD
http://www.ccsinfo.com/forum/viewtopic.php?t=19496&highlight=picdem2
Pushbutton State Machine
http://www.ccsinfo.com/forum/viewtopic.php?t=22145&highlight=picdem2
I just did a forum search in the "Code Library" for "PICDEM2". I know there are many other sample programs that work on a PICDEM2-Plus, but the poster may not have mentioned the target is the PICDEM-2 Plus and thus the 'search' utility didn't catch it.
Neutone
PostPosted: Mon Sep 12, 2005 3:43 pm     Reply with quote
I have several ICD-2 that are still in the wrapper and will probably never see any use. For a while I was using the CCS IDE and opening MPLAB to load my hex files. Now that was several years ago when the ICD-U was not yet fully functional. Now I don't use MPLAB at all and the ICD-2 I have are collecting dust. I find the ICD-U to be a very quick and effective programmer and debugger. The stand alone programming interface is a very big plus as well because it's so easy to use. The PICDEM-2 + is a versital board for development work or just foolin around so you cant hardly go wrong there.
