amal
PIC and Computer interaction |
Posted: Wed Sep 07, 2005 8:28 am |
Hello!!
I try to use PC to control my PIC, but i don't know how to make my own interface (a program on PC to control PIC). Somebody can tell me some tips to write a program to control serial port or parallel port (with C or VB...)? Thanks |
sseidman
Mark
Posted: Wed Sep 07, 2005 11:02 am |
I/O port programming in windows is trivial, especially with VB. VB provides the MSCOMM control. You can find tons of examples doing this.
To do it in Visual C++ isn't that bad either. Here's a snippet from my bootloader app
FUNCTION: EnterBootMode
PURPOSE: This function is provided to open communications to the
PIC through a serial port and place the PIC into bootmode.
The function returns a handle to the opened port or returns a negative number on an error.
INT APIENTRY EnterBootMode(LPSTR ComPort, DWORD BitRate, DWORD ReadTimeOut)
HANDLE hComm;
DCB dcb = {0};
COMMTIMEOUTS CommTmOut = {0};
// Get a handle to the port.
hComm = CreateFile( ComPort,
GENERIC_READ | GENERIC_WRITE,
0,
NULL,
OPEN_EXISTING,
FILE_ATTRIBUTE_NORMAL,
0);
if (hComm == INVALID_HANDLE_VALUE)
return -1;
// Get the current state of the port
FillMemory(&dcb, sizeof(dcb), 0);
if (!GetCommState(hComm, &dcb)){
return -1;
else{
dcb.BaudRate = BitRate;
dcb.Parity = NOPARITY;
dcb.StopBits = ONESTOPBIT;
dcb.fDtrControl = DTR_CONTROL_DISABLE;
dcb.fRtsControl = RTS_CONTROL_DISABLE;
dcb.fOutX = FALSE;
dcb.fInX = FALSE;
dcb.fOutxCtsFlow = FALSE;
dcb.fOutxDsrFlow = FALSE;
dcb.ByteSize = 8;
if (!SetCommState(hComm, &dcb))
return -1;
//Set the timeout conditions
if (!GetCommTimeouts(hComm, &CommTmOut)){
return -1;
else{
CommTmOut.ReadIntervalTimeout = MAXDWORD;
CommTmOut.ReadTotalTimeoutMultiplier = MAXDWORD;
CommTmOut.ReadTotalTimeoutConstant = ReadTimeOut;
if (!SetCommTimeouts(hComm, &CommTmOut))
return -1;
//Send the boot command
if (SendText(hComm, BootCmd, SIZEOFBOOTCMD) != SIZEOFBOOTCMD)
CloseHandle(hComm);
return -1;
CloseHandle(hComm);
return 0;
amal
Posted: Mon Sep 12, 2005 5:31 am |
Sorry about my late reply.
Your information is really helpful. Thanks for showing me the way!!!  |
