How can i measure 4 different impulse width simultaneously
40inD
PostPosted: Tue Sep 06, 2005 4:20 am     Reply with quote
I need to measure 4 different impulse width simultaneously on 4 different inputs. How can i do it? I think to use PIC18F4431. If it can't, wich chip can do it?
SherpaDoug
PostPosted: Tue Sep 06, 2005 2:07 pm     Reply with quote
Can you tell us more about these impulses? Are they synchronized in any way?
One worst case possibility would be to use four really cheap PICs to do the measurements. I once replaced a 386 and an FPGA with 10 PICs and an HC11 at a fraction of the cost and development time.
PostPosted: Tue Sep 06, 2005 3:45 pm     Reply with quote
One approach I used a while back for ten signal inputs was using latches to store the edge trigger until the PIC serviced it and reset the latch.
All this is depending on the speed of all the input signals giving the PIC enough time to get to all the interrupts however but mine worked great...and still does.
40inD
PostPosted: Wed Sep 07, 2005 3:57 am     Reply with quote
These impulses are the standard radiocontrol 20ms impulses with 1 to 2 ms width.
PostPosted: Wed Sep 07, 2005 5:03 am     Reply with quote
I doubt if the pulses will be 'simultaneous'. Normally these pulses are generated as a sequential train for sending over the radio, and the receiver/decoder, then seperates them and feeds them to the servos. There is a 'frame' of time (normally the 20mSec), and pulses are fed to the servos sequentially in this frame. Hence the first servo, receives a pulse of 1 to 2mSec at the start of the frame, then the second servo receives a pulse of 1-2mSec, starting 2.5mSec after the start of the first pulse. The third, receives a pulse of 1-2mSec, starting at 5msec from the first pulse, and the fourth, it's 1-2mSec pulse starting 7.5mSec after the first. The frame size at 20mSec, allows time for eight sequential pulses to be sent. As such, if this is the way the pulses are sent, it simplifies the decoding. However the timescales are long enough, that this can be done reasonably easily.
If you use the 'interrupt on change' ability on portB, to detect the edges on all four signals. In the interrupt handler, work out which edge(s) have occured. For each rising edge, note the value of a seperate timer (program one of the hardware timers to a rate like 10uSec counting). On the falling edge, read the counter again, and subtract the value recorded for the corresponding rising edge. The only problem, will be that if the signals do overlap, errors will be introduced as the interrupt latncy changes when signals occur together. I suspect though you will find that this does not happen.
