18f2520 internal oscillator 16mhz pll enabled rs232 |
Posted: Mon Sep 05, 2005 8:25 am |
i have problem with an 18f2520 running at 16mhz, the rs232 doesn't work
#include <18F2520.h>
#device adc=8
#fuses HS,NOWDT,NOMCLR,INTRC_IO,NOLVP,NOPBADEN,NOBROWNOUT
#use delay(clock=16000000)
#use rs232(baud=38400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9)
oscilator setup:
#asm
MOVLW 0x60
MOVWF 0xFD3
MOVLW 0b11000000
MOVWF 0xF9B
#endasm
the rs232 does not work at all, however the pic boots and apparantle is running at 16mhz.
what to do? |
StuartH
Joined: 19 Aug 2005 Posts: 14 Location: W. Midlands, UK
Posted: Mon Sep 05, 2005 12:59 pm |
Thw 2520/4520 series has some silicon problems. I suggest you read the Silicon Errata document available on the Microchip website to see if any of the information is applicable to you.
As you seem to be using 9 bit mode, you might well be running into one of the documented issues. Check. |
Mark
Posted: Mon Sep 05, 2005 1:01 pm |
From the manual
Quote: | - 8 user selectable frequencies, from 31 kHz to 8 MHz |
So there is no way to get 16MHz using the HS fuse. You would have to configure the osc to 4MHz and use the H4 fuse. CCS provides a setup_oscillator() function. You will probably need to look in the readme file to see how you use it. I believe that it will do the same as your asm routine. Also, do you really need 9 bit data for the RS232? |
Posted: Tue Sep 06, 2005 4:51 am |
You need to read the data sheet. The PLL, when used with the internal oscillator, _is not_ configured by the fuses, but by setting the PLLEN bit, once the code is running.
So setup the fuses like:
#device adc=8
#fuses NOWDT,NOMCLR,INTRC_IO,NOLVP,NOPBADEN,NOBROWNOUT
Then at the start of the code, have:
setup_oscillator(OSC_4MHz | OSC_PLL_ON);
