Eugeneo
Very unpredictable results with -AD volts |
Posted: Tue Sep 06, 2005 1:40 am |
This was so strange I have to share it with the rest of you. Just take a 16FXXX series processor setup an A/D input pin in 10 bit mode. Then put a small negative voltage with respect to ground. The whole chip starts interrupting and crashing.
I always thought there were protection schottky diodes to ground and VCC. |
languer
Posted: Tue Sep 06, 2005 2:09 am |
There are, but you are probably going beyond the maximum ratings. Just out of curiosity, what is the series resistance between this negative supply an the PIC input? ![Twisted Evil](images/smiles/icon_twisted.gif) |
Posted: Tue Sep 06, 2005 2:33 am |
Yes.
The clamp diodes are only 'specified' for voltages above Vdd, not below Vss. The 'input low voltage', is specified as Vss _minimum_. There is also the seperate danger of CMOS latch-up. Though modern gates are designed to make this unlikely, if a -ve voltage is present on the input, before power is applied to the chip, the potential for this does exist...
