Ring Tone Player - Plays ring tones on PICDEM2 plus board
Mark
PostPosted: Thu Feb 24, 2005 12:43 pm     Reply with quote
/*            RTTTL Ring Tone Player for Microchip Microcontrollers          */
/* This program was designed to run on the PICDEM2 Plus demo board from      */
/* Microchip.        */
/* Usage:        */
/*         S3 - Selects Melody                                               */
/*         S2 - Starts/Stops Melody                                          */
/* This code was designed for a clock speed of 20MHz                         */
/* The target device was a PIC18F452.                                        */
/* You can use the PIC16F877 by changing the setup of CCP1 to                */
/* CCP_COMPARE_INT.  You will also need to toggle the output pin in the      */
/* CCP1 interrupt routine.                                                   */
/* Many of the tunes were downloaded from "www.mrtones.com"                  */
#case
#list
#include "18F452.h"
//#include "18F6720.h"
#device *=16
#define CLOCKSPEED     20000000
#define CCP_COMPARE_TOGGLE_MATCH        2
#use delay(CLOCK=CLOCKSPEED)
#fuses HS, NOWDT, NOLVP, PUT
// Include this file after our #use delay
#include "lcd.c"
#define TMR1_PRESCALE  8
#define NOTE_C_SHARP   (((CLOCKSPEED/4)/277.18)/TMR1_PRESCALE)            // 277.18Hz
#define NOTE_D_SHARP   (((CLOCKSPEED/4)/311.13)/TMR1_PRESCALE)            // 311.13 Hz
#define NOTE_F_SHARP   (((CLOCKSPEED/4)/369.99)/TMR1_PRESCALE)            // 369.99 Hz
#define NOTE_G_SHARP   (((CLOCKSPEED/4)/415.30)/TMR1_PRESCALE)            // 415.30 Hz
#define NOTE_A_SHARP   (((CLOCKSPEED/4)/466.16)/TMR1_PRESCALE)            // 466.16 Hz
#define NOTE_C         (((CLOCKSPEED/4)/261.63)/TMR1_PRESCALE)            // 261.63 Hz
#define NOTE_D         (((CLOCKSPEED/4)/293.66)/TMR1_PRESCALE)            // 293.66 Hz
#define NOTE_E         (((CLOCKSPEED/4)/329.63)/TMR1_PRESCALE)            // 329.63 Hz
#define NOTE_F         (((CLOCKSPEED/4)/349.23)/TMR1_PRESCALE)            // 349.23 Hz
#define NOTE_G         (((CLOCKSPEED/4)/392.00)/TMR1_PRESCALE)            // 392.00 Hz
#define NOTE_A         (((CLOCKSPEED/4)/440.00)/TMR1_PRESCALE)            // 440.00 Hz
#define NOTE_B         (((CLOCKSPEED/4)/493.88)/TMR1_PRESCALE)            // 493.88 Hz
#define NOTE_SILENCE   0
#define DURATION_32   5    // Duration = 2^x
#define DURATION_16   4    // Duration = 2^x
#define DURATION_8    3    // Duration = 2^x
#define DURATION_4    2    // Duration = 2^x
#define DURATION_2    1    // Duration = 2^x
#define DURATION_1    0    // Duration = 2^x
typedef enum
  JOLLYOLDSTNICK,
  MOMMYKISSSANTA,
  LETITSNOW,
  AWAYINAMANGER,
  OCHRISTMASTREE,
  MERRYCHRISTMAS,
  SANTACOMING,
  OCOMEALLYEFAITHFUL,
  DECKTHEHALLS,
  SLEIGH,
  RUDOLPH,
  TWELVEDAYSOFCHRISTMAS,
  FROSTYTHESNOWMAN,
  SILENTNIGHT,
  JINGLEBELLS,
  LAST_MELODY
}MELODIES;
typedef struct
  int Head;
  int Tail;
  int Count;
} NOTESTAT;
typedef struct
  long note;
  long duration;
}NOTE_DEF;
struct
  int TRISC0:1;
  int TRISC1:1;
  int TRISC2:1;
  int TRISC3:1;
  int TRISC4:1;
  int TRISC5:1;
  int TRISC6:1;
  int TRISC7:1;
}TRISCbits;
#locate TRISCbits = 0xF94
long TMR1;
#locate TMR1 = 0xFCE
int TMR1L;
#locate TMR1L = 0xFCE
int TMR1H;
#locate TMR1H = 0xFCF
int TMR0;
#locate TMR0 = 0xFD6
#define   MAX_NOTE_BUFFER_SIZE  4
#define   NOTE_ROLLOVER_MASK     0b00000011
NOTE_DEF  NoteBuffer[MAX_NOTE_BUFFER_SIZE];
NOTESTAT  Notestat = {0,0,0};
long      DurationCount=0;
int       Tempo=0;
long      Note_Ticks=0;
MELODIES  Melody_Pointer;
long      Note_Index = 0xFFFF;
BOOLEAN   PlayMelodyFlag = TRUE;
int       Read_Button_Count = 0;
const struct
  char tune[107];
  int  defaultoctave;
  int  defaultduration;
  int  tempo;
}JollyOldStNick ={
                   {"a,a,a,a,g,g,2g,f,f,f,f,1a,d,d,d,d,c,c,2f,g,f,g,a,1g,a,a,a,a,g,g,2g,f,f,f,f,1a,d,d,d,d,c,c,2f,g,f,g,a,1f,1p"},
                   5,
                   DURATION_4,
                   160
const struct
  char tune[263];
  int  defaultoctave;
  int  tempo;
}MommyKissSanta ={
                   {"2c.,d,e,g,a,8c6,2b.,g,1e,a,g,e,c,a,g,e,8c.,1b.,f,e,d,d.,8c#.,2d.,8a.,16b.,8a.,g.,f#.,8a.,2g.,e,d,e,f#,g,a,g#,a,a#,b,a,f,8e,2d.,g,2c.,d,e,g,a,8c6,1b,g,1e,a,g,2e,16c,a,g,e,8c.,1a,16g#,8a.,16b,c6,8c.6,c6,8d.6,1b,f#,8a.,16a,g,f,8e,2d,8e.,2f,g,a,8c.6,a,2c6,2d6,1c6,1p"},
                   5,
                   DURATION_4,
                   160
const struct
  char tune[218];
  int  defaultoctave;
  int  tempo;
}LetItSnow ={
              {"8c,8c,8c6,8c6,a#,a,g,f,2c,8c,16c,g.,8f,g.,8f,e,2c,d,8d6,8d6,c6,a#,a,2g.,8e.6,16d6,c6,8c.6,16a#,a,8a#.,16a,2f.,c,8c6,8c6,a#,a,g,f,2c,8c.,16c,g.,8f,g.,8f,e,2c,d,8d6,8d6,c6,a#,a,2g.,8e.6,16d6,c6,8c.6,16a#,a,8a.,16g,2f,1p"},
              5,
              DURATION_4,
              125
const struct
  char tune[175];
  int  defaultoctave;
  int  tempo;
}AwayInAManger ={
                  {"d6,d.6,8c6,b,b.,8a,g,g,f#,e,2d,d,d.,8e,d,d,a,f#,e,d,g,2b,d6,d.6,8c6,b,b.,8a,g,g,f#,e,2d,d,c.6,8b,a,b,a,g,a,e,f#,2g,d6,d.6,8c6,b,b.,8a,g,g,f#,e,2d,d,d.,8e,d,d,a,f#,e,d,g,2b,1p"},
                  5,
                  DURATION_4,
                  112
const struct
  char tune[243];
  int  defaultoctave;
  int  tempo;
}OChristmasTree = {
                    {"4c.,4f,f,4f.,4g.,4a,a,2a,16p,a.,g.,a.,4a#.,4e.,4g.,4f.,4c.,4f,f,4f.,4g.,4a,a,2a,16p,a.,g.,a.,4a#.,4e.,4g.,2f,16p,c.6,c.6,a.,2d6,16p,c.6,c.6,a#.,2a#,16p,a#.,a#.,g.,2c6,16p,a#.,a#.,a.,4a.,4c.,4f,f,4f.,4g.,4a,a,2a,16p,a.,g.,a.,4a#.,4e.,4g.,2f,1p"},
                    5,
                    DURATION_8,
                    160
const struct
  char tune[159];
  int  defaultoctave;
  int  tempo;
}MerryChristmas = {
                    {"4c,4f,f,g,f,e,4d,4a#4,4d,4g,g,a,g,f,4e,4c,4e,4a,a,a#,a,g,4f,4d,c,c,4d,4g,4e,4f.,p,4c,4f,4f,4f,4e.,p,4e,4f,4e,4d,4c.,p,4c,4a,g,g,f,f,4c6,4c,c,c,4d,4g,4e,4f.,1p"},
                    5,
                    DURATION_8,
                    140
const struct
  char tune[110];
  int  defaultoctave;
  int  tempo;
}SantaComing = {
                 {"4g,8e.,f.,4g,4g.,p,g.,8a.,b.,4c6,4c.6,8p,8e.,f.,4g,4g.,p,g.,8a.,g.,4f,4f.,8p,4e,4g,4c,4e,4d,4f.,8p,4b4,4c.,1p"},
                 5,
                 DURATION_16,
                 160
const struct
  char tune[226];
  int  defaultoctave;
  int  tempo;
}OComeAllYeFaithful = {
                        {"c.,4c.,g.5,c.,4d.,4g.5,e.,d.,e.,f.,e.,d.,c.,4c.,b.5,a.5,b.5,c.,d.,e.,4b.5,4a5,16g.5,4g.5,4p.,4g.,f.,e.,4f.,4e.,d.,e.,c.,d.,4b5,16a.5,g.5,c.,c.,b.5,c.,d.,4c.,g.5,e.,e.,d.,e.,f.,4e.,d.,e.,f.,e.,d.,c.,4b.5,c.,f.,e.,4d,16c.,4c,1p"},
                        6,
                        DURATION_8,
                        112
const struct
  char tune[156];
  int  defaultoctave;
  int  tempo;
}DeckTheHalls = {
                  {"c6.,8a#,a,g,f,g,a,f,8g,8a,8a#,8g,a.,8g,f,e,2f,16p,c6.,8a#,a,g,f,g,a,f,8g,8a,8a#,8g,a.,8g,f,e,2f,16p,g.,8a,a#,g,a.,8a#,c6,g,8a,8b,c6,8d6,8e6,f6,e6,d6,2c6,1p"},
                  5,
                  DURATION_4,
                  160
  /* Sleigh */
const struct
  char tune[202];
  int  defaultoctave;
  int  tempo;
}Sleigh = {
            {"8b,8b,8b,8b,8c#6,b,g#,8e,8f#,8g#,f#,e,8c#,2b4,4p,b4,c#,e,g#,8b,8c#6,b,g#,f#,e,8f,f#,g#,f#,e,8c#,2e,8p,8b,8b,8b,8c#6,b,g#,8e,8f#,8g#,f#,e,8c#,2b4,4p,b4,c#,e,g#,8b,8c#6,b,g#,f#,e,8f#,f#,g#,f#,e,8c#,8e,1p"},
            5,
            DURATION_16,
            112
  /* Rudolph */
const struct
  char tune[208];
  int  defaultoctave;
  int  tempo;
}Rudolph = {
             {"d,e,16d,b.5,g.,e.,4d.,p.,d,16e,d,16e,d.,g.,4f#.,4p.,c,d.,16c,a.5,f#.,e.,4d.,p.,d,16e,d,16e,d.,e.,4b.5,4p.,d,e.,16d,b.5,g.,e.,d.,p.,d,16e,d,16e,d.,g.,f#.,4p.,c,d.,16c,a.5,f#.,e.,4d.,p.,d,16e,d,16e,d.,a.,g.,1p"},
             6,
             DURATION_8,
             112
const struct
  char tune[175];
  int  defaultoctave;
  int  tempo;
}TwelveDaysOfChristmas = {
                           {"c.,c.,8c,f.,f.,8f.,e.,f.,g.,a.,a#.,g.,4a,p,a#.,8c.6,d.6,a#.,a.,f.,8g.,4f.,8p,c.,c.,c.,f.,f.,f.,8f.,e.,f.,g.,a.,a#.,g.,4a.,8c.6,g.,a.,8a#.,a.,a#.,8c.6,d.6,a#.,a.,f.,8g.,4f.,1p"},
                           5,
                           DURATION_16,
                           112
const struct
  char tune[176];
  int  defaultoctave;
  int  tempo;
}FrostyTheSnowman = {
                      {"g.,8p,e.,8f,g,c.6,8p,8b,8c6,d6,c6,b,a,2g,p,8b,8c6,d6,c6,b,a,8g,c6,e.,8g,8a,g,f,e,d,g.,2p,g.,8p,e.,8f,g,c.6,8p,8b,8c6,d6,c6,b,a,2g,p,8b,8c6,d6,c6,b,a,g,c6,e,8g,8a,g,f,e,d,c.,1p"},
                      5,
                      DURATION_4,
                      180
const struct
  char tune[192];
  int  defaultoctave;
  int  tempo;
}SilentNight = {
                 {"f#.,8g#,f#,d#.,p.,f#.,8g#,f#,d#.,p.,2c#6,c#6,a#.,p.,2b,b,f#.,p.,2g#,g#,b.,8a#,g#,f#.,8g#,f#,d#.,p.,2g#,g#,b.,8a#,g#,f#.,8g#,f#,d#.,p.,2c#6,c#6,e.6,8c#6,a#,2b.,2d#6,p.,b,f#,d#,f#.,8e,c#,b.4,1p"},
                 5,
                 DURATION_4,
                 140
const struct
  char tune[202];
  int  defaultoctave;
  int  tempo;
}JingleBells = {
                 {"8e.,8e.,e.,8e.,8e.,e.,8e.,8g.,c,16d.,2e,p,8f.,8f.,f,16f.,8f.,8e.,8e.,16e.,16e.,8e.,8d.,8d.,8e.,d.,g.,8e.,8e.,e.,8e.,8e.,e.,8e.,8g.,c,16d.,2e,p,8f.,8f.,f,16f.,8f.,8e.,8e.,16e.,16e.,8g.,8g.,8f.,8d.,c.,1p"},
                 5,
                 DURATION_4,
                 180
/* Function Prototypes */
void InitTimer(void);
int PlayMelody();
void PlayNote(long note, int octave, int duration);
char get_char_from_tune(long index);
int get_tempo(void);
int get_defaultoctave(void);
int get_defaultduration(void);
void display_melody_name(void);
void Melody_Task(void);
void Button_Task(void);
void Check_Button_Press(void);
// Start of Code
  DESCRIPTION:  This function handles checking for button presses
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  TRISCbits.TRISC2 = 0;
  InitTimer();
  Melody_Pointer = JINGLEBELLS;
  display_melody_name();
    Button_Task();
    Melody_Task();
  DESCRIPTION:  This function handles the playing of a melody
  RETURN:       True if the melody is still active or False if its complete
  ALGORITHM:    none
  NOTES:        none
int PlayMelody(void)
  int octave = 0;
  int duration = 0;
  long note = 0;
  // Check for a valid Melody
  if (Melody_Pointer >= LAST_MELODY)
    // Reset the Melody to the start
    Melody_Pointer = 0;
  // Load notes while we have enough room
  while (Notestat.Count < MAX_NOTE_BUFFER_SIZE)
    // Is this the first note?
    if (Note_Index == 0xFFFF)
      Tempo = get_tempo();
      Note_Index = 0;
    // Set Default duration
    duration = get_defaultduration();
    // Set Default Octave
    octave = get_defaultoctave();
    // Play a bit of slience between notes
    if (get_char_from_tune(Note_Index) == ',')
      PlayNote(0, 4, DURATION_32);
      Note_Index++;
      return(TRUE);
    // We are checking the duration
    else if ((get_char_from_tune(Note_Index) == '3') && (get_char_from_tune(Note_Index+1) == '2'))
      duration = DURATION_32;
      Note_Index += 2;
    else if ((get_char_from_tune(Note_Index) == '1') && (get_char_from_tune(Note_Index+1) == '6'))
      duration = DURATION_16;
      Note_Index += 2;
    else if (get_char_from_tune(Note_Index) == '8')
      duration = DURATION_8;
      Note_Index++;
    else if (get_char_from_tune(Note_Index) == '4')
      duration = DURATION_4;
      Note_Index++;
    else if (get_char_from_tune(Note_Index) == '2')
      duration = DURATION_2;
      Note_Index++;
    else if (get_char_from_tune(Note_Index) == '1')
      duration = DURATION_1;
      Note_Index++;
    // Now we get the note
    switch (get_char_from_tune(Note_Index++))
      case 'c':
        if (get_char_from_tune(Note_Index) == '#')
          note = NOTE_C_SHARP;
          Note_Index++;
          note = NOTE_C;
      case 'd':
          note = NOTE_D_SHARP;
          Note_Index++;
          note = NOTE_D;
      case 'e':
        note = NOTE_E;
      case 'f':
          note = NOTE_F_SHARP;
          Note_Index++;
          note = NOTE_F;
      case 'g':
          note = NOTE_G_SHARP;
          Note_Index++;
          note = NOTE_G;
      case 'a':
          note = NOTE_A_SHARP;
          Note_Index++;
          note = NOTE_A;
      case 'b':
        note = NOTE_B;
      case 'p': // slience
        note = NOTE_SILENCE;
    // See if this note is 1.5x the duration
    if (get_char_from_tune(Note_Index) == '.')
      // Use the MSB to signify 1.5x
      duration |= 0x80;
      Note_Index++;
    // Get the octave
    switch (get_char_from_tune(Note_Index))
      case '4':
        octave = 4;
        Note_Index++;
      case '5':
        octave = 5;
        Note_Index++;
      case '6':
        octave = 6;
        Note_Index++;
      case '7':
        octave = 7;
        Note_Index++;
      default:
    // Sometimes the duration multiplier comes after the octave
      /* Duration 1.5x */
      duration |= 0x80;
      Note_Index++;
    // Play the note (we actually just load it in a buffer
    PlayNote(note, octave, duration);
    // Is this the end?
    if (get_char_from_tune(Note_Index) == 0)
      return(FALSE);
    return(TRUE);
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  long duration_count;
  // Process octave
  switch (octave)
    case 4 :
    case 5 :
      note = note >> 1;
    case 6 :
      note = note >> 2;
    case 7 :
      note = note >> 4;
  // Process Note Duration
  duration_count = 256;
  duration_count >>= (duration & 0x7F);
  // If duration is 1.5x add .5 to duration
  if (duration & 0x80)
    duration_count += (duration_count >> 1);
  // Add the note to our buffer
  NoteBuffer[Notestat.Tail].note = note;
  NoteBuffer[Notestat.Tail].duration = duration_count;
  Notestat.Tail++;
  Notestat.Tail &= NOTE_ROLLOVER_MASK;
  Notestat.Count++;
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  setup_timer_0(RTCC_DIV_256 | RTCC_8_BIT);
  setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
  setup_timer_2(T2_DIV_BY_4, 250, 5);
  enable_interrupts(INT_CCP1);
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  switch (Melody_Pointer)
    case JOLLYOLDSTNICK:
      return (JollyOldStNick.tune[index]);
    case MOMMYKISSSANTA:
      return (MommyKissSanta.tune[index]);
    case LETITSNOW:
      return (LetItSnow.tune[index]);
    case AWAYINAMANGER:
      return (AwayInAManger.tune[index]);
    case OCHRISTMASTREE:
      return (OChristmasTree.tune[index]);
    case MERRYCHRISTMAS:
      return (MerryChristmas.tune[index]);
    case SANTACOMING:
      return (SantaComing.tune[index]);
    case OCOMEALLYEFAITHFUL:
      return (OComeAllYeFaithful.tune[index]);
    case DECKTHEHALLS:
      return (DeckTheHalls.tune[index]);
    case SLEIGH:
      return (Sleigh.tune[index]);
    case RUDOLPH:
      return (Rudolph.tune[index]);
    case TWELVEDAYSOFCHRISTMAS:
      return (TwelveDaysOfChristmas.tune[index]);
    case FROSTYTHESNOWMAN:
      return (FrostyTheSnowman.tune[index]);
    case SILENTNIGHT:
      return (SilentNight.tune[index]);
    case JINGLEBELLS:
      return (JingleBells.tune[index]);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
int get_tempo(void)
      return (JollyOldStNick.tempo);
      return (MommyKissSanta.tempo);
    case LETITSNOW:
      return (LetItSnow.tempo);
    case AWAYINAMANGER:
      return (AwayInAManger.tempo);
      return (OChristmasTree.tempo);
      return (MerryChristmas.tempo);
    case SANTACOMING:
      return (SantaComing.tempo);
      return (OComeAllYeFaithful.tempo);
    case DECKTHEHALLS:
      return (DeckTheHalls.tempo);
    case SLEIGH:
      return (Sleigh.tempo);
    case RUDOLPH:
      return (Rudolph.tempo);
      return (TwelveDaysOfChristmas.tempo);
      return (FrostyTheSnowman.tempo);
    case SILENTNIGHT:
      return (SilentNight.tempo);
    case JINGLEBELLS:
      return (JingleBells.tempo);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
      return (JollyOldStNick.defaultoctave);
      return (MommyKissSanta.defaultoctave);
    case LETITSNOW:
      return (LetItSnow.defaultoctave);
    case AWAYINAMANGER:
      return (AwayInAManger.defaultoctave);
      return (OChristmasTree.defaultoctave);
      return (MerryChristmas.defaultoctave);
    case SANTACOMING:
      return (SantaComing.defaultoctave);
      return (OComeAllYeFaithful.defaultoctave);
    case DECKTHEHALLS:
      return (DeckTheHalls.defaultoctave);
    case SLEIGH:
      return (Sleigh.defaultoctave);
    case RUDOLPH:
      return (Rudolph.defaultoctave);
      return (TwelveDaysOfChristmas.defaultoctave);
      return (FrostyTheSnowman.defaultoctave);
    case SILENTNIGHT:
      return (SilentNight.defaultoctave);
    case JINGLEBELLS:
      return (JingleBells.defaultoctave);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
      return (JollyOldStNick.defaultduration);
      return (MommyKissSanta.defaultduration);
    case LETITSNOW:
      return (LetItSnow.defaultduration);
    case AWAYINAMANGER:
      return (AwayInAManger.defaultduration);
      return (OChristmasTree.defaultduration);
      return (MerryChristmas.defaultduration);
    case SANTACOMING:
      return (SantaComing.defaultduration);
      return (OComeAllYeFaithful.defaultduration);
    case DECKTHEHALLS:
      return (DeckTheHalls.defaultduration);
    case SLEIGH:
      return (Sleigh.defaultduration);
    case RUDOLPH:
      return (Rudolph.defaultduration);
      return (TwelveDaysOfChristmas.defaultduration);
      return (FrostyTheSnowman.defaultduration);
    case SILENTNIGHT:
      return (SilentNight.defaultduration);
    case JINGLEBELLS:
      return (JingleBells.defaultduration);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  if (PlayMelodyFlag)
    if (!PlayMelody())
      Melody_Pointer++;
  DESCRIPTION:  This function displays the title of the melody on the LCD
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  // Clear the screen and make sure that we are at the top
  lcd_putc("\f");
  lcd_gotoxy(0,1);
  // Use our global Melody_Pointer to determine the title of the current tune
      lcd_putc("Jolly Old\nSt Nick");
      lcd_putc("Mommy Kissing\nSanta Claus");
    case LETITSNOW:
      lcd_putc("Let It Snow");
    case AWAYINAMANGER:
      lcd_putc("Away In A Manger");
      lcd_putc("O Christmas Tree");
      lcd_putc("We Wish You A\nMerry Christmas");
    case SANTACOMING:
      lcd_putc("Santa Claus Is\nComing To Town");
      lcd_putc("O Come All\nYe Faithful");
    case DECKTHEHALLS:
      lcd_putc("Deck The Halls");
    case SLEIGH:
      lcd_putc("Sleigh Ride");
    case RUDOLPH:
      lcd_putc("Rudolph");
      lcd_putc("Twelve Days\nOf Christmas");
      lcd_putc("Frosty The\nSnowman");
    case SILENTNIGHT:
      lcd_putc("Silent Night");
    case JINGLEBELLS:
      lcd_putc("JingleBells");
     default:
  DESCRIPTION:  Button Tasks
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  if (!Read_Button_Count)
    Read_Button_Count = 30;
    Check_Button_Press();
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  static int debounce_count = 4;
  static int stable = 0xFF;
  static int last = 0xFF;
  int trans_low;
  int current = 0xFF;
  BOOLEAN change = FALSE;
  // Read the current state of the buttons
  if (!input(PIN_A4))
    bit_clear(current,2);
  if (!input(PIN_B0))
    bit_clear(current,3);
  // See if they have changed
  if (current != last)
    last = current;
    change = TRUE;
  // If they have changed then reset our counter
  if (change)
    debounce_count = 4;
  // Each time they are stable, then decrement our count
  else if (debounce_count)
    debounce_count--;
  // They have been stable long enough so act on them
  else if (current != stable)
    // Get the high transitions
    trans_low = ((stable ^ current) & stable);
    if (bit_test(trans_low,2))
      PlayMelodyFlag = ! PlayMelodyFlag;
    if (bit_test(trans_low,3))
      Melody_Pointer++;
        Melody_Pointer = 0;
    stable = current;
// ISR routines
#int_ccp1
  DESCRIPTION:  This function controls the PWM of the piezo speaker
  RETURN:       none
  ALGORITHM:    none
  NOTES:  If you do not wish to use C2 as the output, then you will need
          to toggle your output here.  Make sure that you change the CCP
          setup not to toggle the C2 output if this is the case
void ccp1_isr (void)
  CCP_1 += Note_Ticks;
  DESCRIPTION:  This function is used to control the duration of the note
  RETURN:       none
  ALGORITHM:    none
  NOTES:  I store the notes in a buffer so that the main loop has other
          time to do stuff with out have to sit at wait for a note to
          complete.
#int_timer0
void timer0_isr (void)
  // Preload a value for TMR0 so that we can control how long it takes to
  // trigger an interrupt
  TMR0 = Tempo;
  // Is a note playing?
  if (DurationCount)
    DurationCount--;
    if (!DurationCount)
      setup_ccp1(CCP_OFF);
  // Note is finished playing, do we have anymore in our buffer?
  else if (Notestat.Count)
    DurationCount = NoteBuffer[Notestat.Head].duration;
    Note_Ticks = NoteBuffer[Notestat.Head].note;
    Notestat.Count--;
    Notestat.Head++;
    Notestat.Head &= NOTE_ROLLOVER_MASK;
    CCP_1 = TMR1 + Note_Ticks;
    if (Note_Ticks)
      /* Setup the CCP module to toggle the output pin c2 */
      setup_ccp1(CCP_COMPARE_TOGGLE_MATCH);
    // Nope, we are all through so disable the PWM
#int_timer2
  DESCRIPTION:  This function is our system tick set at 1ms
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
void timer2_isr (void)
  if (Read_Button_Count)
    Read_Button_Count--;
hillcraft
RTTTL format
PostPosted: Fri Sep 02, 2005 5:46 am     Reply with quote
I have this program running on the PICDEM 2 PLUS. It works very well. I have now obtained a couple of songs off the net and replaced some of the original songs.
I do have problem and it is that the songs seem to play very slowly.
Take this song "Hit the road jack" for example: it was designed for Nokia phones
const struct
  char tune[156];
  int  defaultoctave;
  int  tempo;
}HitTheRoadJack ={
                   { "18g.,12p,18f.,3g.,d,p,18d.,18f.,12p,18f.,9g.,12p,9g.,12p,9a.,12p,a,d6,d6,f6,f6,f6,9d.6,12p,18g.,12p,18f.,3g.,d,p,18d.,18f.,12p,18f.,9g.,12p,9g.,12p,9f.,2d."},
                   5,
                   DURATION_4,
                   160
Should I be getting songs for a particular cell phone?
Mark
PostPosted: Fri Sep 02, 2005 6:10 am     Reply with quote
Did the song specify the defaultoctave, defaultduration, and tempo or did you just make those values up?
Also, the note durations are invalid. This is the number before the note. Legal values are nothing (default duration), 1, 2, 4, 8, 16, 32
hillcraft
RTTTL Hit the road Jack
PostPosted: Fri Sep 02, 2005 8:30 am     Reply with quote
The defaults were specified.
Here is the URL - you will see that most of the songs have long durations.
http://www.free-ringtones.uk.com/Hit-The-Road-Jack.html
Mark
PostPosted: Fri Sep 02, 2005 8:41 am     Reply with quote
You'll have to change the durations to a valid number. The "." means 1.5X the duration. So 18f. is really 27f so 16f. would give you 24. 3g. is 4.5 so just use 4g and so on
hillcraft
PostPosted: Fri Sep 02, 2005 8:54 am     Reply with quote
Fair enough. Do you know of a site that has valid music that I could use.
www.mrtunes.com seems to have become a victim of a websquatter.
hillcraft
PostPosted: Fri Sep 02, 2005 9:08 am     Reply with quote
Don't worry about the URL - I have found numerous sites. I have loaded a song and it works perfectly.
Mark
PostPosted: Fri Sep 02, 2005 9:10 am     Reply with quote
You can also modify the code to allow the other values. Binary values are great because they end up being shifts.
      Note_Index += 2;
This just sets duration to a value to shift by. It could just as well be a number to divide by, in this case 32. So long as the PIC has enough time to do the divide, there should not be a problem. So the play note would now be:
  // Process octave
  switch (octave)
    case 4 :
    case 5 :
      note = note >> 1;
    case 6 :
      note = note >> 2;
    case 7 :
      note = note >> 4;
  duration_count /= (duration & 0x7F);
  Notestat.Tail++;
  Notestat.Count++;
And the tones you have will work. You will probably want to replace the If...else if statements that get the duration to something else like
  duration = 0;
  while (isdigit(get_char_from_tune(Note_Index)))
    duration *= 10;
    duration += (get_char_from_tune(Note_Index) - '0');
    Note_Index++;
  // Set Default duration if there wasn't one specified
  if (duration == 0)
jtf
PostPosted: Mon Jan 08, 2007 9:58 am     Reply with quote
Thanks for the code, it works perfectly. I am little confused with the tempo.
If tempo is 150 (= bpm, right?) then tmr0 will overflow
0.2us * 256 * (255 - 150) = 5376us and with default duration (= one note = one beat) it will take 5376us * 64 = 344.064ms to play that one note. So my result is not 150bpm. Where is the mistake?
I would like to run it on 8MHz and I don't know how I should set the timers.
Mark
PostPosted: Wed Jan 17, 2007 1:17 pm     Reply with quote
tempo doesn't have to be in bpm. It just represents how fast or slow a song is played. You could modify the code I guess to make it work out that way or just adjust the values in the const structs. From your calculations, 150 turns out to be 172. Not too far off. It was written to be fast. If you want to actually calculate the timer value, it would be 256 - ((60*ClockSpeed)/(TEMP*65536)) or 256-(7324/TEMPO)
filjoa
PostPosted: Thu Dec 03, 2009 9:24 am     Reply with quote
hi
I copy this program to my ccs give errors on lcd.c :s
some one know why?
what is pin to S2 and S3?
best regards
Mark
PostPosted: Thu Dec 03, 2009 10:34 am     Reply with quote
  if (!input(PIN_A4))
  if (!input(PIN_B0))
    last = current;
    change = TRUE;
  if (change)
    debounce_count = 4;
    debounce_count--;
      Melody_Pointer++;
        Melody_Pointer = 0;
From the above code we see that A4 sets bit 2 and B0 set bit 3. Bit 2 (Pin A4) starts and stops and Bit 3 (Pin B0) increments melody.
filjoa
PostPosted: Thu Dec 03, 2009 1:59 pm     Reply with quote
hi
why the error on lcd.c? you edit them?
best regards
