Debugging arrow on MPLAB off by 2 lines
usafape
PostPosted: Thu Sep 01, 2005 7:33 am     Reply with quote
Hi all,
Does anyone know why the green arrow is off by two lines down when using MPLAB (7.20)?
Please advice. Thanks,
FabioP
RobM
Re: Debugging arrow on MPLAB off by 2 lines
PostPosted: Thu Sep 01, 2005 9:56 am     Reply with quote
usafape wrote:
Hi all,
FabioP
Most lilkely you have edited your source file but not re-compiled. I have seen it before...
Rob
_______
usafape
PostPosted: Thu Sep 01, 2005 9:58 am     Reply with quote
NOPE... I don't think that is the case... this is happenning even right after I compile the code.
FabioP
valemike
PostPosted: Thu Sep 01, 2005 2:45 pm     Reply with quote
Yup, happens to me all the time, especially after a while-statement or if-statement, right?
i am guessing it's got to do with the underlying assemby code that it is stepping thru.
I got around all that by just printf'ing everything that concerns me onto hyperterminal.
Mark
PostPosted: Thu Sep 01, 2005 5:34 pm     Reply with quote
What is the version of the compiler?
usafape
PostPosted: Fri Sep 02, 2005 6:26 am     Reply with quote
3.182
PhilWinder
PostPosted: Sat Sep 03, 2005 1:57 pm     Reply with quote
Im guessing that you are using the ICD2 (or equivilent). This is normal and is describe in numerous manuals. Check them out.
If you are not using the ICD2 to debug, then what are you using????
Phil Winder
usafape
PostPosted: Tue Sep 06, 2005 6:19 am     Reply with quote
Phil Winder
I am using the MPLAB simulator.
Fabio
