PIC16F84 and DS1307 dosen't work properly
Bombay
PostPosted: Wed Aug 31, 2005 4:34 am     Reply with quote
Hi
I 'm start my digital clock project with PIC16F84 and DS1307 but
the PIC16F84PIC16F84 and DS1307 dosen't work properly.
It can't even enable oscillator for DS1307. I use I2C driver from CCS
example.
Now I looking for a new source code for ds1307.
Please
PostPosted: Wed Aug 31, 2005 4:52 am     Reply with quote
I'd look again at your wiring to the chips, things like the pull-up resistors on the I2C lines, which pins are connected, make sure no other peripheral is using the pins, and verify that each line is working properly.
The demo code _does_ work.
If the problem is still not obvious, come back with how you have things connected, what compiler version you are using etc..
asmallri
PostPosted: Wed Aug 31, 2005 5:49 am     Reply with quote
Have you connected the battery? The DS1307 will no work correctly without it.
Regards, Andrew
MAX3000
PostPosted: Wed Aug 31, 2005 11:35 am     Reply with quote
Hi Bombay
Are you sure ?
1.You must pull-up SDA and SCL pin with R 10K
2.Connect 3V battery to DS1307
3.What frequency of your crystal
more detail check out this DS1307 Example
Bombay
PostPosted: Thu Sep 01, 2005 12:05 pm     Reply with quote
Thank every body.
I have programming as MAX3000 introduce but it still dosen't work.
I don't know what is the problem.
My crystal 4 MHz and also connected 3V battery to DS1307 with R10 K pull-up on SDA and SCL pin.
Please help
Thank.
BB
Mark
PostPosted: Thu Sep 01, 2005 12:07 pm     Reply with quote
I think they are asking the crystal speed connected to the DS1307.
PostPosted: Thu Sep 01, 2005 2:21 pm     Reply with quote
What voltage is the PIC running at?. This one is 'vital'. The DS1307, won't allow you to talk to it, till the main supply rail reaches at least 1.25* the voltage on the battery pin. If the battery pin has (say) a lithium battry operating at 3.3v, the PIC's supply, must be over 4.125v, for the unit to work. This one can be very much a problem, when some batteries 'out of the box', give slightly more voltage than they are meant to give...
