USB descriptor
prayami
USB descriptor
PostPosted: Tue Aug 30, 2005 9:37 pm     Reply with quote
Hi..I have succefully run the CCS example program for USB using
18F4550. In this example there are two variables PIC is sending to PC.
And two variables that PIC can receive from PC. So total four variable.
Now I want to modify that:
I want to send only one variable from PIC to PC. For testing let say
the variable is of 8bit. But after that I may require to send 10bits of
data or variable from PIC to PC.
As per I understand, I require to modify in the usb_desc_hid.h file
only.
(1) Is there any other file, I require to change?
(2) What exactly I require to change? I tried to change the descriptor
file but it is not working. Anybody know, at what places I have to
modify to do the above job.
Any idea appreciated.......
prayami
PostPosted: Thu Sep 01, 2005 5:58 pm     Reply with quote
Is there anybody who know, How can "usb_desc_hid.h" file modified?
I want to send only one variable from PIC to PC? I tried to modified
ther same file but it is not easy to understand that file.
Thanks...
PostPosted: Mon Sep 05, 2005 8:43 am     Reply with quote
I'm in trouble with pic18 and USB.
I'm studing about example and I'm interest to try also HID example but I don't now how PC work and start to write code in builder c++.
How can I write to PC with HID ?
Is it an comunication port to write with terminal or need a driver ?
prayami
PostPosted: Mon Sep 05, 2005 8:06 pm     Reply with quote
For PC side I used the driver from Trace Systems Inc.
i.e. www.tracesystemsinc.com
It is not eary to write this code on PC side ourselves. Try driver
like this.
