mm:ss:dd subtraction ?
PostPosted: Tue Aug 30, 2005 1:31 am     Reply with quote
I have a number of mm:ss:dd where mm is minutes, ss is second and dd is tenth of second, my problem is subtraction to 8? that is es:
01:32:01 - 00:00:08 = xx:xx:xx
02:01:05 - 00:00:08 = xx:xx:xx
............ - 00:00:08 = xx:xx:xx
As I can make subtraction?
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
Re: mm:ss:dd subtraction ?
PostPosted: Tue Aug 30, 2005 5:56 am     Reply with quote
Make the following math operation:
((1 * 60 * 60) + (32 * 60) + 1) - 8
This will give you the number of seconds (a very big number)
Then convert the big number back to hh:mm:ss
Think first of the math on how you would do it. Then write the corresponding source code.
PostPosted: Tue Aug 30, 2005 6:11 am     Reply with quote
thanks very much!
Mark
PostPosted: Tue Aug 30, 2005 6:16 am     Reply with quote
From math class:
  signed int8 minutes, seconds, tenths;
  // Init some values
  minutes = 1;
  seconds = 32;
  tenths = 1;
  // Subtract the 8
  tenths -= 8;
  // See if we need to borrow 1
  if (tenths < 0)
    // We did so add 1 or 10 tenths
    tenths += 10;
    // Borrow it
    seconds--;
    // Do we need to borrow a minute?
    if (seconds < 0)
      // Yep, so do it
      seconds += 60;
      minutes--;
      // Maybe you want to check for negative here!
