lcd.c limitation
JGoodman
lcd.c limitation
PostPosted: Mon Aug 29, 2005 7:00 am     Reply with quote
I may just be doing something wrong, but it seems like the lcd.c library which ccs provides is somewhat limited. I can only ouput characters that I type into the function call e.g. lcd_putc("Hello"). It does not seem like I can send strings or variables to this function e.g. char bob[6]="hello"; lcd_putc(bob);
Any advice?
-Thanks.
Mark
PostPosted: Mon Aug 29, 2005 7:18 am     Reply with quote
Did you even look at what the parameter for lcd_putc() is????? If you want to pass something else, write your own function or wrap the function inside another. you can also use the printf function with lcd_putc
  char *pointer;
  pointer = bob;
  while (*pointer)
    lcd_putc(*pointer);
    pointer++;
  printf(lcd_putc,"Hello");
  printf(lcd_putc,"%S",bob);
JGoodman
PostPosted: Mon Aug 29, 2005 7:49 am     Reply with quote
Thank you very much, that did the trick!
J G
