#define a string
#define a string
PostPosted: Sat Aug 27, 2005 3:40 pm     Reply with quote
Is this permitted? #define string (char*)"hi"
If not, any suggestions?
Mark
PostPosted: Sat Aug 27, 2005 4:43 pm     Reply with quote
pointers to constants are not allowed.
PostPosted: Sat Aug 27, 2005 4:55 pm     Reply with quote
would you happen to have a suggestion to perform a string compare against a string that is not allowed to changed? ie if(strcmp(guess, my permanent strig) then do something
Mark
PostPosted: Sat Aug 27, 2005 5:20 pm     Reply with quote
Look in the help file for strcmp(). You will find an example for strcat() that can be used for your problem.
PostPosted: Sat Aug 27, 2005 5:49 pm     Reply with quote
Thank you for the suggestion. Please forgive me but I don't understand how concatenation can solve the problem? could you please give an example?
PostPosted: Sat Aug 27, 2005 9:44 pm     Reply with quote
In CCS, the strcmp() function on works with strings that are in ram arrays.
So, if you have a constant string, you need to copy it into a ram array
by using the special CCS function, strcpy(). Then you can use strcmp().
#include <16F877.H>
#use delay(clock = 4000000)
const char Hello_string[] = "Hello";   // This string is in ROM
char temp[20];
strcpy(temp, Hello_string); // Copy const string into ram array
// Now you can use strcmp() to compare temp to another array.
// Put your strcmp() code here.
Mark
PostPosted: Sun Aug 28, 2005 2:13 am     Reply with quote
It can't but if you look at the example and think just a bit you will see that you can apply the same principle but instead of strcat() do your strcmp()!
PostPosted: Sun Aug 28, 2005 11:31 am     Reply with quote
Thanks,
Eric
