(Off Topic) Battery Voltage Detector
jecottrell
PostPosted: Fri Aug 26, 2005 9:08 pm     Reply with quote
I think this has been covered before, but I couldn't find the topic.
How does one control the power to a voltage divider to sense the battery voltage? This is a 4 AA powered app that runs at either 3 or 5V and needs to last as long as possible. So, the goal is to only power the voltage divider to the ADC when taking a reading.
The topology below is an obvious option. Simply set RA4 as an input to power it up. Take a reading and then turn it off.....
However, I remember there being some issues with the configuration....
       Vbat(6V)
          |___________ AN0
          |___________ RA4
Thanks,
John
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Fri Aug 26, 2005 9:46 pm     Reply with quote
When you put the RA4 into the high-Z state, +6V will appear on AN0 and RA4, and +6V is higher then the max allowed voltage. You could ground the bottom of the divider and add a small MOSFET (like 2N7000) in series with the top resistor. Or you could pick the higest possible values for the resistors, and have the smallest leakage. I remeber that the maximum value for the lower resistor is 2.5k, this was mentioned in the PIC's datasheet.
jecottrell
PostPosted: Fri Aug 26, 2005 10:01 pm     Reply with quote
Thanks Kender,
I can't believe that didn't dawn on me. I'll go the FET route and everything should workout.
John
kender
PostPosted: Fri Aug 26, 2005 10:09 pm     Reply with quote
kender wrote:
... add a small MOSFET (like 2N7000) in series with the top resistor.
Come to think of it, it should be a P-channel MOSFET, because it's a high-side switch (2N7000 will not work). You could also use a high-side switch IC.
jecottrell
PostPosted: Fri Aug 26, 2005 10:44 pm     Reply with quote
Wouldn't have caught that one. I've got other designs using FETs and they are always on the ground leg (low-side). Probably would have plowed right into the wall. Thanks for the correction.
I Googled and found this option:
http://www.micrel.com/product-info/products/mic2514.shtml
Printing out the data sheet now to read up on. Just another wild Friday night!
