What is wrong with a nested while loop
pic_user
PostPosted: Fri Aug 26, 2005 6:29 pm     Reply with quote
I have the following C code:
void detect_key()
valid_key = 0;
valid_low = 0;
valid_high = 0;
while (!valid_key)
while (!valid_low) detect_low();
while (!valid_high) detect_high();
When I look at the compiler output I get the following:
111: void detect_key()
112:
113: {
114: valid_key = 0;
0043 01A0 CLRF 0x20
115: valid_low = 0;
0044 01A1 CLRF 0x21
116: valid_high = 0;
0045 01A2 CLRF 0x22
117:
118: while (!valid_key)
119:
120: {
0046 08A0 MOVF 0x20, F
0047 1D03 BTFSS 0x3, 0x2
0048 285A GOTO 0x5a
121: {while (!valid_low) detect_low();}
0049 08A1 MOVF 0x21, F
004A 1903 BTFSC 0x3, 0x2
004B 2849 GOTO 0x49
122: {while (!valid_high) detect_high();}
004C 08A2 MOVF 0x22, F
004D 1D03 BTFSS 0x3, 0x2
004E 2859 GOTO 0x59
0058 284C GOTO 0x4c
123: }
0059 2846 GOTO 0x46
124: }
125:
If you compare the "BTFSS 0x3, 0x2 " in 0047, with the "BTFSC 0x3, 0x2" in 0049 the result is different - and wrong.
Is it illegitmate to have nested while loops?
PostPosted: Fri Aug 26, 2005 6:49 pm     Reply with quote
How is it wrong ?
The code stays in each loop while the Z flag is set.
It jumps out of each loop when the Z flag is cleared.
I don't know what version of the compiler you have.
I think you want to see cleaner code. The latest
version (PCM vs. 3.232) produces the following code,
which you will probably like better:
0000                00336 ... while (!valid_key)
0000                00337 ... {
0021 08A1       00338 MOVF   21,F
0022 1D03       00339 BTFSS  03.2
0023 282B       00340 GOTO   02B
0000            00341 .. while (!valid_low) detect_low();
0024 08A2       00342 MOVF   22,F
0025 1903       00343 BTFSC  03.2
0026 2804       00344 GOTO   004
0000            00345 ..while (!valid_high) detect_high();
0027 08A3       00346 MOVF   23,F
0028 1903       00347 BTFSC  03.2
0029 2809       00348 GOTO   009
0000                00349 ...}
002A 2821       00350 GOTO   021
pic_user
Isn't it still wrong?
PostPosted: Fri Aug 26, 2005 7:12 pm     Reply with quote
Here is your code:
0000 00337 ... {
0000 00349 ...}
Let me highlight the following
Shouldn't these all be the same, BTFSS 03.2 ?
By the way, I was wrong in what I presented. The output of my compiler - the demo version - actually produced the right code. What happened was that I later invoked the compiler from MPLAB IDE, which is where I got the code I listed originally.
I am totally confused as to why I get different results from the compiler standalone versus from MPLAB, and also why the MPLAB does not give all BTFSS.
And to further complicate it, I don't know what to make of the latest compiler output.
Mark
PostPosted: Fri Aug 26, 2005 7:24 pm     Reply with quote
Nope
Look at what it is doing. Skipping if clear. So if it is set (zero) then goto 4 which is where detect_low() is.
pic_user
PostPosted: Fri Aug 26, 2005 7:37 pm     Reply with quote
Mark,
Yes I agree. But wouldn't the same apply to the first while:
In other words shouldn't this be BTFSC also? It seems to me that all the while statements should give the same result.
Mark
PostPosted: Sat Aug 27, 2005 6:35 am     Reply with quote
pic_user wrote:
Mark,
Nope, what does it say: Skip if set so in other other if it is zero then skip that goto instruction and execute the while statement below. Just what you wanted. Don't expect every while (0) function to generate the same code. The compiler uses optimization and does what would be the smallest code. Doing it your way would require 2 goto statements. Don't worry about the asm code. Just write your code in C.
