Source code for Master and Slave SPI
Aquiles
PostPosted: Fri Aug 26, 2005 10:47 am     Reply with quote
Hello All,
Does any body have an example for use SPI protocol for a PIC acting as a Master and Slave (two PICs connected)?
Also, what directive is used to enable SPI: #USE RS232 or #USE I2C.
I am using the PIC16F873A chip.
Thanks.
Aquiles.
PostPosted: Fri Aug 26, 2005 12:02 pm     Reply with quote
There is no #use statement for SPI.
You can do it two ways: Use the hardware SPI module in the PIC,
with the CCS functions, such as setup_spi(), spi_write(), etc.
Or, you can do software spi:
http://www.ccsinfo.com/forum/viewtopic.php?t=23791
