Help on BIT definition please
Rocket
PostPosted: Fri Aug 26, 2005 2:20 am     Reply with quote
Hi all. I need to make a driver, that works for the 16 and 18 parts.
And the input signal can be on CCP1 in or CCP2 in, so this is where I fall off the bus. My code looks like this..
#if defined(__PCH__)
#if defined use_CCP2
   #byte CCP_CON = 0xFBA             // CCP2CON Reg
   #bit CCP_Flag = 0xFA1,0        // CCP2IF  FLAG
#else
   #byte CCP_CON = 0xFBD             // CCP1CON Reg
   #bit CCP_Flag = 0xF9E,2         // CCP1IF  FLAG
#endif
   #byte PIR1    = 0xF9E         // PIR1 Reg
#else
   #byte CCP_CON = 0x1D                // CCP2CON Reg
   #bit CCP_Flag = 0x0D,0          // CCP2IF  FLAG
#else
   #byte CCP_CON = 0x17                  // CCP1CON Reg
   #bit CCP_Flag = 0x0C,2                  // CCP1IF  FLAG
#endif
   #byte PIR1    = 0x0C                      // PIR1 Reg
#endif
the "#bit" does not work, and i need to test for the relevant CCP interupt flag in my program..
Thanx..
PostPosted: Fri Aug 26, 2005 2:46 am     Reply with quote
The 'bit' seperator, is a '.' not a ','...
#bit CCP_Flag = 0xFA1.0 // CCP2IF FLAG
