		| Author | Message |
		| pic_user
				| Why am I getting function definition different from previous |
				|  Posted: Thu Aug 25, 2005 10:50 pm |   |
				| Why am I getting error(29): function definition different from previous definition wait_dly Param#3
 #include <16f877a.h>
 #DEFINE FIRST_VAL    100
 #DEFINE SECOND_VAL   200
 #FUSES HS, NOWDT, NOPROTECT, PUT
 void wait_dly  ( wait_val, wait_cnt)
 unsigned long int wait_cnt,wait_val;
 unsigned long int  i, delay = 0;
 set_timer1(0);
 for(i=0; i = wait_val*2 ; i++)
 while (delay < wait_cnt)
 delay = get_timer1();
 set_timer1(0);
 /************************* MAIN ***********************/
 wait_dly(CHANGE_VAL,CHANGE_VAL);
		| PCM programmer
				|  Posted: Thu Aug 25, 2005 11:35 pm |   |
				| You're using the original K&R style of function declarations from the 1978 edition of their book.    You need to do it the modern way, like this:
  	  | Code: |  	  | void wait_dly(unsigned long int wait_val, unsigned long int wait_cnt)
 set_timer1(0);
 // etc.
		| pic_user
				| Thanks for the help |
				|  Posted: Fri Aug 26, 2005 6:20 pm |   |
				| Thanks for the help. As it turns out I had experimented and did what you suggest. I thought the way I did it was still valid C. It is true that I am using old books as I try to come up to C. |  |
