JGoodman
Why is my functional function not functioning??? |
Posted: Thu Aug 25, 2005 9:46 am |
The compiler is giving me a bunch of strange errors for a function which I see no problem with. I even compiled it with gcc and it worked fine! Could someone tell me what I am doing wrong?
Here's my code:
// This function is used to compare two arrays of equal length.
// Returns '1' if arrays are identical, returns '0' if not
short compare_array(int length, int array1[], int array2[])
length=(length-1);
int num=length; // (This is line 45)
int result=1;
while(num>=0)
if(array1[num]!=array2[num])
result=0;
num--;
return result;
Now here is what the compiler had to say:
*** Error 51 "E:\picprojects\pic c\menu_data.c" Line 45(2,5): A numeric expression must appear here
*** Error 51 "E:\picprojects\pic c\menu_data.c" Line 46(2,5): A numeric expression must appear here
*** Error 12 "E:\picprojects\pic c\menu_data.c" Line 48(8,11): Undefined identifier num
*** Error 12 "E:\picprojects\pic c\menu_data.c" Line 50(13,16): Undefined identifier num
*** Error 12 "E:\picprojects\pic c\menu_data.c" Line 52(4,10): Undefined identifier result
*** Error 12 "E:\picprojects\pic c\menu_data.c" Line 54(3,6): Undefined identifier num
*** Error 12 "E:\picprojects\pic c\menu_data.c" Line 56(10,16): Undefined identifier result
Posted: Thu Aug 25, 2005 9:59 am |
Change it to the following:
Code: | short compare_array(int length, int array1[], int array2[])
int num;
int result=1;
length=(length-1);
num=length; |
Also, just to make sure you know it, in CCS a "short" is one bit,
and an "int" is an 8-bit unsigned value. |
JGoodman
Posted: Thu Aug 25, 2005 10:12 am |
Thank you,
This fixed it.
Could you explain why the ccs compliler is particular about this and gcc is not?
Thanks.
-J Goodman |
rwyoung
Posted: Thu Aug 25, 2005 12:03 pm |
JGoodman wrote: | Thank you,
This fixed it.
Thanks.
-J Goodman |
Prior to C++ (which GCC uses by default if I remember correctly) all declarations had to occur prior to executable instructions. Good ol' C requires this. If you turn off the C++ support in GCC it would throw errors/warnings too. _________________ Rob Young
