2 wire interface to a PIC using C? Is it i2c?
bwgames
PostPosted: Thu Aug 25, 2005 4:14 am     Reply with quote
Hiya,
I'm trying to intergrate a programmable oscillator (DS1077 (link to datasheet/info etc)) into a circuit, in place of a crystal oscillator.
What I'm looking to do is to be able to program it on the fly from a PIC, and according to a very informative AppNote (AppNote 171), I've got an idea of how to program it, but unfortuately the code is in assembler, not C.
Its two pins, one a clock signal, the other data, which isn't that difficult.
I had major problems trying to get a similar circuit to work for another application, so I'm looking at ways of speeding it up.
I'm new to PIC programming, but is I2C any relevance to what I want to do? I keep hearing mentions of it on the forums, but I don't have a great understanding of what it is...
valemike
PostPosted: Thu Aug 25, 2005 7:48 am     Reply with quote
First of all, you should look at the timing diagrams to see if it truly is i2c-like or proprietary.
Also, "2-Wire interface" seems to be a term that is synonymous with i2c. It's just the company doesn't want to get in legal trouble with Philips who has that name trademarked.
rwyoung
PostPosted: Thu Aug 25, 2005 8:10 am     Reply with quote
It is I2C. Also, Maxim does have an application note for writing PC C code to program the part through a parallel port.
Rob Young
bwgames
PostPosted: Thu Aug 25, 2005 8:13 am     Reply with quote
I've read the PC parallel notes, but I'm looking to control it from a PIC, is it simple enough to adapt the code?
Thanks Smile
PostPosted: Thu Aug 25, 2005 8:15 am     Reply with quote
The big 'caveat', is that you either have to set your I2C rate to always be 'in spec' at the fastest clock rate, or you need to change the I2C speed definitions, when you change the multiplier byte in the chip.
If you use the software I2C implementation, and add a new USE_DELAY statement for the new rate, once the speed change occurs, the compiler _should_ handle this for you...
